[FS] Titanium conical wheel bolts M14x1.5x48
Category: Wheels & Tires
Price: $300
Part fits: Porsche 911 997 Turbo, Porsche 911 997 Non-Turbo, Porsche 911 996 Turbo, Porsche 911 996 Non-Turbo, Porsche Cayenne, Porsche Boxter/Cayman, Porsche Panamera, Older Porsche, Ferrari, Lamborghini, Maserati, Aston Martin, Bentley, Nissan GTR, American vehicles, Other
Item Condition: Brand New
-Surface plated with Titanium Nitride for additional hardness
-Corrosion resistance
-M14x1.5x48(total length)
-Suitable only for wheels with conical seats
Price for 20 pcs.
This (below). Not at all clear what is being offered here. Ti bolts or just Ti coated. What exactly is the spec of the bolt material?
V
V
This is solid Ti with TiNi coating.
No, suitable only for non-OEM wheels with conical seats.
Bolts are made from solid Ti alloy.
Material: Ti6Al4V
Material: Ti6Al4V
Code:
Physical Properties Metric English Density 4.43 g/cc 0.16 lb/inі Mechanical Properties Hardness, Brinell 334 334 Estimated from Rockwell C. Hardness, Knoop 363 363 Estimated from Rockwell C. Hardness, Rockwell C 36 36 Hardness, Vickers 349 349 Estimated from Rockwell C. Tensile Strength, Ultimate 950 MPa 138000 psi Tensile Strength, Yield 880 MPa 128000 psi Elongation at Break 14 % 14 % Reduction of Area 36 % 36 % Modulus of Elasticity 113.8 GPa 16500 ksi Compressive Yield Strength 970 MPa 141000 psi Notched Tensile Strength 1450 MPa 210000 psi Kt (stress concentration factor) = 6.7 Ultimate Bearing Strength 1860 MPa 270000 psi e/D = 2 Bearing Yield Strength 1480 MPa 215000 psi e/D = 2 Poisson's Ratio 0.342 0.342 Charpy Impact 17 J 12.5 ft-lb V-notch Fatigue Strength 240 MPa 34800 psi at 1E+7 cycles. Kt (stress concentration factor) = 3.3 Fatigue Strength 510 MPa 74000 psi Unnotched 10,000,000 Cycles Fracture Toughness 75 MPa-mЅ 68.3 ksi-inЅ Shear Modulus 44 GPa 6380 ksi Shear Strength 550 MPa 79800 psi Ultimate shear strength
04-28-2022 12:38 AM
RS GT3 RS
09-24-2015 09:27 PM
