03 Torch Red Mustang Cobra Vert Built
Old Feb 5, 2014 | 03:05 PM
wan2play's Avatar
wan2play is infamous around these parts
Year: 2003
Make: Ford
Model: Mustang
Price: $21500
Mileage: 38800
Color: Torch Red
Location (State): IL
Transmission: Manual
Drivetrain: Rear Wheel Drive
2003 SVT Cobra Convertible
38,8XX miles
Clean title in hand
Carfax available upon request
Located in Chicago, IL
Gauging some interest in the car over this Winter. I do not need to sell the car, but I am entertaining offers. I'm sure most of you have been there and done that.
Only trades I accept are for luxury cars only with cash on top of trade.
Looking for $21,500 OBO
RECENT MAINTENANCE:
-New Ford Racing alternator
-New clutch cable (stock)
-Rear Axle
CONDITION OF VEHICLE:
Exterior:
-A couple touched up rock chips on the hood. Nothing major, but noticeable from up close.
-3rd brake light is cracked on either end.
-Convertible top in great condition. NO tears or scratches.
-Looks like a 9/10 overall. Well kept.
Interior:
-Left door card not holding firmly. However, it does not pop out. Only when forced will it slightly move. Small amount of play.
-Other than that, the interior is in excellent condition.
Engine:
-Everything that needed to be replaced was replaced.
-Cross-over pipe was leaking due to shrunken O-rings. They were replaced over a month ago. NO more leak.
-Dip stick bracket is broken off. Because there are longtubes, replacing it would require their removal. However, Tim recommended a flexible modular dipstick. Costs around $60....Easy fix.
Suspension:
-I was experiencing some coil bind. So I raised the front coils 3/4th of an inch. NO big deal.
-Everything else has plenty of life left.
Brakes:
-Wilwood Pads have over 80% life left, the material does have a slight squeak every now and then. Nothing horrible.
Wheels/Tires:
-Front tires have maybe 2k on them.
-Rear tires will need to be replaced soon. But still derivable for another 1000 miles or so.
There is an extensive mod list. Add it all up, minus the recent $8,000 I spent on the new motor, parts and labor total around $20k.
ENGINE:
The NEW MMR block consists of the following:
-mmr 900 shortblock - Cast Iron 2004 Cobra Block (std bore)
-4340 Forged 3.543 stroke Cobra Crankshaft
-4340 5.933 MMR 900HP H-beam Rods w/ARP rod bolts
-Forged Manley pistons -18cc (low compression for boost)
-Total Seal file fit rings
-Clevite Rod and Main bearings
-ARP 2000 Head Studs
-Arp Main Studs
-MMR Side bolts
-MELLING High Performance Oil Pump w/Billet Gears #10227
-15/16 Pick up tube
-Moroso Oil Pan
-Steggy stage IV port
-JDM 3.0 Pully
-2# power
-Metco Idler with snub
-Accufab TB and plenum
-JLT HiBoost CAI
-BA2400 MAF
-SCT Xcalibrator 2
-PCV Catch Can
-ROn Davis H/E
-Valve covers painted Ford Racing Blue
FUELING:
-60Lb injectors
-AEM Wideband O2
-KenneBell Boost-a-pump
EXHAUST:
-Bassani catback
-Bassani catted X-pipe
-Kook's Long tube header
(the car sounds amazing)
TRANSMISSION:
-D&D Viper Spec T-56
-Fidanza aluminum flywheel
-Spec stage 3 clutch
-26 spline input shaft
-Steeda Tri-ax SS
-Steeda Quadrant and Adjuster
DRIVETRAIN/REAREND:
-Dynotech aluminum driveshaft
-Welded mid length sub frame connectors
-Flush IRS bolts
-Billerflow IRS brace
-Kenny Brown Torque Brace
-Aluminum diff mounts
SUSPENSION:
-Tubular K-member
-MM CC plates
-MM coilover fronts
-Eibach Pro Rears
-Steeda bump steer kit
BRAKES:
-14" slotted 6 piston Wilwood kit
-Stainless lines
WHEELS:
-Black Chrome FR500 18x10.5 rear and 18x9 front
-Nitto 555r
-1/2inch spacers
-3 Inch studs
My number is 773 510-2737 email pmazurek1@comcast.net
THE CAR CAN BE VOUCHED FOR BY TIM BARTH AT MPH OR JORDAN OF MPH
You can contact Tim or Jordan directly through their land line at 1(815) 636-2784
He is a busy man and answers emails more frequently than the phone.
mphracing@yahoo.com
The Midwest has been hit hard by snow, so the only pictures I have are the following...
http://www.flickr.com/photos/113343905@N05/11742346246/]20130709_193407_6~2[/url, on Flickr
http://www.flickr.com/photos/113343905@N05/11741993794/]20130712_193002~2[/url, on Flickr
http://www.flickr.com/photos/113343905@N05/11741838253/]20130712_193011~2[/url, on Flickr
http://www.flickr.com/photos/113343905@N05/11742343956/]20130928_105227(1)[/url, on Flickr
ID:	329752   Click image for larger version
ID:	329753   Click image for larger version
ID:	329754   Click image for larger version
ID:	329755   Click image for larger version
ID:	329759   Click image for larger version
ID:	329760   Click image for larger version
Old Feb 5, 2014 | 07:41 PM
LSACadzilla's Avatar
LSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud ofLSACadzilla has much to be proud of
That's a super clean looking termi! Any paintwork or all original?
Jul 29, 2019 11:13 AM
Sep 1, 2015 03:16 PM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
