Built 6 speed Audi Allroad
Year: 2002
Make: Audi
Model: allroad
Price: $23500
Mileage: 88900
Color: Silver
Location (State): PA
Transmission: Manual
Drivetrain: 4WD & AWD
ENGINE
2.8 cylinder heads
rs4 intake camshaft
Rosten piston rods
Autospeed (Also known as ASP out of NJ) fueling (630 cc siemens deka fuel injectors)
044 fuel pump
Swaintech friction coated main and rod bearings, thermal barrier on piston tops and cyclinder heads/valves
rs6 turbos
Ported intake manifold to match 2.8 heads
Phenolic intake manifold space
ER intercoolers
X1 carbon fiber intake
Devils own professional installed methanol injection system. This is tapped into the bi-pipe and is mounted in trunk.
Oil cooler
EXHAUST
RS6 Sound enhanced exhaust
3'' downpipes with high flow catalytic converters
TRANSMISSION
6 speed swap with kryo'd internals and new 1st, 2nd gear syncros
SouthBend Stage 5 clutch
Torsen 4:1 center diff (rear wheel bias)
TDI 6th gear -longer gearing for better gas mileage (or higher top speed). Try finding a TDI 6th gear with cruise control. I had this car reprogrammed for the TDI gear and the cruise runs puuuuurfect.
trans cooler
INTERIOR
RNS-E Navigation system
Bluetooth hands free (works great)
IPOD integration
All Weather floor mats
European interior with door cards including Alcantara seats with door cards (probably the only car in the US with this interior. It was shipped from Europe).
Heated front and rear seats.
Heated steering wheel.
SUSPENSION/BRAKES
Replaced the problematic air-ride with Variant V-3 coilovers. Adjustable dampening and rebound. These are awesome. Literally changed the way the car handled when installed.
ASP Drive train stabilizer.
Alcon 6 piston front brakes
S8 rear brake upgrade with Alcon rotors
EXTERIOR
Depo clear front headlghts
Professionally made RS4 grill (by a metal worker)
LED tails
Fully chromed BBS RS-GT 20x9 on cooper rs3-s filled with nitrogen
Comes with stock rims with winter Hancook Icebear winter tires
Painted fenders, front and rear bumpers to match body paint to give it the european rs4 widebody "look".
The car was dyno tuned by ASP and is conservatively tuned to 24 psi on meth and made 465 wheel hp on a mustang dyno. It could make 500 whp easy on the setup. ASP setup has made the car a wireless hot spot and I can change the tune on the car with an Iphone app I downloaded. There is a 93 tune, a 104 tune (meth), valet mode, and theft mode. It's a pretty awesome feature. The car is not a daily driver. It's driven once a week, but tuned such that it could be a daily driver and the feel is smooth. I've driven this car to the beach and back with no problems.
The only bad I can think of is the normal rock chips on the front, a scratch on the rear bumper that is in the picture. You can barely see it. Also, before I purchased the car the previous owner had a slight accident where he was side swiped. The rear fender flair needed to be replace and the rear panel needed painting. There was no frame damage, suspension damage, etc. It was not a major accident, but wanted full disclosure as it will show up on a VIN report.
I'm sure I'm missing some modifications as I've dumped a ton into this car, but I can provide more pictures and videos upon request. Again, this car is literally one of kind, drives great and subtle, and would be a great daily driver. About a week ago I had an audi tech replace the timing belt and water pump with factory equipment so that there is no question that this vehicle is operating fantasically. The timing belt and water pump are warrantied as oem for a year. This will also come with three 1-gallon water/meth Devils Own mix.
Thanks. Driving the car and seeing it in person is the only way to do it justice. Thanks for the comments
Jul 29, 2019 11:13 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
