2009 UGR TT LP560 (1550hp)
Old May 22, 2014 | 11:53 AM
Mattz's Avatar
Mattz is infamous around these parts
Year: 2009
Make: Lamborghini
Model: Gallardo
Price: $365000
Mileage: 4000
Color: Matte Black
Location (State): CA
Transmission: Automatic
Drivetrain: 4WD & AWD
Willing to trade for LP670 or LFA OBO...
The AWD system and Motec Boost by gear puts down power on the street and honestly is incredibly easy to drive.
Here is a quick clip from when we took the car out to Los Angeles...
Underground has the transmission and quick shift program down especially with the high HP build, billet internals and the updated gearing for maximum flexibility... the car takes off from a stop smoother than stock, shifts as fast as a Superleggera, starts like OEM, drives in traffic like OEM, and hauls ***... it honestly drives better than a stock gallardo e-gear...
This is one of three (?) i think factory matte black LP560 which we have converted now to the full LP570 body kit... for those of you who want a little bit more comfort it has the LP560 interior which is quieter, leather everywhere and the comfortable buckets with diamond cross stitching...
Car is not obnoxiously loud and is downright enjoyable to drive in traffic... under WOT the car sounds fantastic but not ear blowing loud...
honestly, the only reason I am considering moving the car, is that i have numerous projects being completed and am looking at a couple crazy new projects in the very near future...
here are some pictures and details of the build... i have an incredible amount of money put into this build as we have not spared any expense..
here are some - car has just over 3K miles on it with about 500 on the car since completion... (i know i know... not enough driving for sure!)
2009 Lamborghini Gallardo LP560-4 with LP570 conversion body kit
- Ceramic brakes
- Carbon interior package
- Matte black paint
- Navigation
- Backup camera
Stage 1 Race Version
1100+ WHP using Pump Gas
1500+ WHP using Race Gas
- Custom twin Billet Race turbochargers
- Tial billet wastegates
- Tial billet blow off valves
- Custom fabricated stainless steel exhaust using aircraft quality metal
- Ultra lightweight stainless steel mufflers
- Polished exhaust finish
- Custom fabricated stainless steel air induction using aircraft quality metal
- K&N air filters
- High quality silicone hose
- High pressure T-bolt clamps for intake pressure tubes
- High quality v-band clamps for exhaust connections
- Custom heat shielding and high quality heat wrap
- Custom Air/Water intercooler system with high flow water pump
- High flow intercooler water heat exchanger
- Custom ice water reservoir.
- Crankcase ventilation system
- Seat sleeves for aluminum block
Underground Custom Billet Short Block
- Full blue print and balanced race short block
- Disassemble complete Lamborghini V10
- Install custom block sleeves
- Bore & hone V10 with torque plate
- Machine block deck surface V10 Aluminum
- Machine block deck surface V10 Sleeves
- Balance complete V10 rotating assembly
- Mallory for balancing crankshaft
- Polish and mic crankshaft
- Jet clean block
- Jet clean cylinder heads
- Carrillo billet rods
- CP custom reverse dish race pistons
- CP spiral locks
- CP .180+ wall wrist pins
- CP oil rail support
- Custom steel cylinder sleeves
- Main bearings
- Rod bearings
- Total seal TNT file fit rings
- Assemble complete Lamborghini V10
Cylinder Heads
- Race Version heads
- ARP cylinder head studs
Fuel System
- Two custom billet fuel pump hangers with high flow fuel pumps
- Custom aluminum fuel rails
- All Aeroquip stainless steel fuel line and aluminum fittings
- Aeromotive adjustable fuel pressure regulator
- Upgraded fuel injectors
Transmission Upgrade
- Billet 1st thru 6th gear set
- Custom final drive gear set
Clutch
- Tilton clutch, pressure plate and flywheel
Quick Shift Upgrade
- Hardware
- Wiring harness
- Software setup
Tuning
- MoTeC Engine Management System
- Boost by Gear
- Custom wiring harness
Carbon Ceramic Brakes
- Paint brakes matte red with Lamborghini stenciling in black
Super Rare Wheels
- HRE Carbon Fiber Series wheels
New Toyo Tires
Lights
- Tint side marker and brake lights
Name:	Screen Shot 2014-05-20 at 3.13.08 PM.png
ID:	377520   Click image for larger version
Name:	Screen Shot 2014-05-20 at 3.12.39 PM.png
ID:	377523   Click image for larger version
Name:	Screen Shot 2014-05-20 at 3.11.57 PM.png
Old May 22, 2014 | 12:37 PM
GT3 Chuck's Avatar
Administrator
Required actual item photos ASAP please
Old May 22, 2014 | 12:45 PM
Mattz's Avatar
okay
Old May 22, 2014 | 12:49 PM
GT3 Chuck's Avatar
Administrator
Thanks...glws...just sent a pm
tita1989
Aug 17, 2016 03:13 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Oscar 987
Sep 29, 2015 04:57 PM
r1rb
Sep 27, 2015 12:06 PM
