2005 Mercedes E55 AMG
Year: 2005
Make: Mercedes-Benz
Model: E-Class
Price: $17500
Mileage: 110000
Color: Pewter
Location (State): CO
Transmission: Automatic
Drivetrain: Rear Wheel Drive
New Tires: Brand new Toyo Proxes T1 Sports front and rear (245/40/18 and 285/30/18 front and rear respectively)
Brakes all around: new OEM Mercedes rotors and Akebono ceramic pads in January
Full fluids flush: New Mobil 1, coolant, transmission fluid, diff oil, supercharger oil also in January
Valve cover seals also redone in January: no leaks
As these cars are known to suffer from heat soak from the factory, I have also upgraded the cooling system and had the system split so that the engine and supercharger have separate coolant paths, upgraded the heat exchanger up front (Eurocharged), upgraded the coolant system pump (Bosch 010), and even added a trunk tank to increase the volume of coolant available.
The car is also tuned (both ECU - Eurocharged, and TCU - BIP), has a clutched upper supercharger pulley as well as a belt wrap and idler pulley kit, and to top it off has been upgraded to 3.06 rear gears and I have added a Mercedes P30 performance package LSD.
Last, it's sitting on plastidipped (just redid these last week) SL55 wheels that have a much more aggressive offset than stock E55 wheels.
The only failure I have had on the car was the front right Airmatic shock, so it's been replaced with an Arnott Industries lifetime warranty shock.
I have been working with a local master Mercedes tech running an independent shop, and he has taken a liking to the car and says it's in great shape overall.
Bottom line, the car runs great and I'm sure will go on to the next owner that will appreciate it being in fantastic condition for its age. I have taken some pics and put them in an imgur gallery:
http://imgur.com/a/u16vo
Carfax I saved from last year when I bought the car:
https://www.dropbox.com/s/bqv0lmdtr7...BENZ%20E55.pdf
Hopefully I'm not forgetting anything. Car has 110k miles. Price lowered to $17500 or best offer. Please let me know if you have any questions. Thanks!
(more pics in gallery: http://imgur.com/a/u16vo)
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
