2002 Porsche 996 C2 Cab (997 Facelift) Prior Design / Techart / Fabspeed.
Year: 2002
Make: Porsche
Model: 911
Price: $27000
Mileage: 73000
Color: Seal Grey
Location (State): FL
Transmission: Manual
Drivetrain: Rear Wheel Drive
Since I had it, I've driven it less than 2k miles, however, I drive it on a weekly basis 1 or 2 days, back and fourth to the gym, etc. So it's "staying alive".
Pros:
- IMS Bearing installed less than 500 miles ago
- Fabspeed exhaust (no tips yet, I have OEM) (less than 1k miles)
- Prior design PD3 front end converted to 997 with 99.71 headlights, and 997.2 fogs (less than 500 miles)
- 997.2 fogs / led / blinker full functional with OEM Switch
- GT2 style wheels (white) less than 1k miles with tires
- Fully adjustable Yellow DPS coilover system (less than 1k miles)
- Interior rear is mint, front is near perfect with a "fade" stain on the driver seat, I've put product on it and eliminated the "fade", it comes back after a few months.
- Techart style rear bumper (less than 500 miles)
- GT3 style side rockers (less than 500 miles)
- carbon fiber mirror covers (less than 500 miles)
- soft top is 100% fully functional, works without any issues, up and down fast
Cons:
- 99% complete, requires a little of work
- NO exhaust tips installed (I have OEM which bolt right on)
- Side rockers need to be adjusted and installed properly (they are test fitted on with 3m tape)
- Primer still visible on the 2 pillars along with scratches (easy to touch up)
- Fenders need to be re-aligned a little (easy, just adjust the screws)
- Front driver side headlight has small crack on lens, you should replace it
- front passenger side headlight needs to be buffed and cleaned (yellowish tint, not bad, see pics)
- Fender on driver side is too close to door
- soft top has the typical "wear" seen on these for being closed for too long
- rear passenger window regulator is shot, needs to be replaced
- front windows do not go down the inch or so they need to when you open the door, this is a common problem, most 996's i've seen have this problem, you might need a new regulator, or you can do one of the many "fixes" to solve this.
The interior has all the parts, i took it apart to install my navigation, however, I'm looking to buy a 997.1 GT3, so I've decided not to finish it, all I have to do is put the dash parts back together.
I also have all the OEM front bumper, OEM rear bumper, and Techart style side skirts.
rocker needs to be pushed up and installed properly. Primer and installation wear exists, obviously it can be covered up by simply touching it up and moving the rocker up.
3m tape is visible, you need to reinstall rockers.
Techart style rear.
Rear shot
soft top wear
soft top wear
interior is mint
small fade on driver seat, goes away with leather cleaner
dash is mint, i need to assemble it.
rear is mint
mint
excessive primer on pillar, scratches, needs touching up
mint
mint
2lflat4
Nov 18, 2019 05:05 PM
joseph_number1
Jul 19, 2018 05:45 PM
