FS: 2001 Audi S4 STG III Silver sedan, very clean, no winters
Old Jan 7, 2015 | 07:23 AM
Gewaltakt's Avatar
Gewaltakt is infamous around these parts
Year: 2001
Make: Audi
Model: S4
Price: $14000
Mileage: 141000
Color: silver
Location (State): NC
Transmission: Manual
Drivetrain: 4WD & AWD
This pains me to do...
2001 Audi S4 Stage 3, Silver 6speed - $14k OBO (yes that means I will accept a lower price, but you have to suggest it)
For sale is my well cared for and maintained 2001 Audi S4. I am the second owner and had always planned to be its last, but life and priorities change. It is a southern car, It has never seen a salty or snowy winter (I garaged and maintained it during the winters when it was in Wisconsin for 6 years). There is no corrosion or rust on this car, the aluminum still looks new. The car is very clean and well sorted to be a daily driver. It is clean both inside, outside AND underneath. I am a meticulous person and this car has been my pride and joy for 8 years. I have been a professional race car mechanic for the past 15 years and I have cared for and prepared this car with the same attention as if it was going to Le Mans 24. The car is silver (yes the fastest color) with the onyx interior (black). It has a clean title and is ready to be sold.
The bad,
* This Audi Is 14 years old and has had a well-cared for life but still has its rock chips and other small blemishes.
* The headliner is in need of attention as it is starting to sag a bit (common and fixable)
* The center display is starting to succumb to missing pixels (common problem and about ~$100 to fix)
* The windscreen washer bottle is currently not installed but I have it.
The good,
It's a well sorted Stg 3 S4 battle axe that still looks sexy and can throw down with the best of them.
ENGINE - Audi 2.7 V6 Twin Turbo ~141k (~400 HP at the wheels)
* EPL Stg3 including upgrade turbos(BW K04's strong and healthy), plumbing, fuel injectors, programming, etc. (base tune)
* Heat wrapped inlet pipes
* Gold foil heat protection on frame rails and firwalls
* Ceramic coated APR bi-pipe (gold foiled as well) plumbed for Aquamist
* New timing belt done @122k miles along with cam tensioner seals, VC gaskets, water pump, thermostat, etc...
* Custom recirc system with catch tank, Staubli fittings for quick removal. ($400 fittings)
* Painted red valve covers (you can feel the difference in your but dyno)
* New alternator
* New water tank & cap (no longer yellow, is now white/ clear)
* After run pump delete
* ER IC's W/ carbon shrouds
* 710N diverter valves
* N75 relocation behind secondary firewall (temperature stable)
* Phenolic spacers on intake manifold, as well ceramic coated intake mani with heat shielding (lower air intake temp = more power)
* New water pipes/ hoses and o-rings
* New crank position sensor (replaced as precaution when changing clutch)
* Not installed Aquamist HSF-3 kit with 3gallon tank - car is ready for install and meth tune
* MTM F-pipe (not installed with new recirc system)
* Ceramic coated exhaust manifolds
* APR downpipes with test pipes and cats (interchangeable)
* AWE Twin 1 exhaust (same exhaust in this video,
GEARBOX
* New AMD high performance Clutch
* ASP rear diff mount
* Polyurethane rear diff carrier bushings
* Center drive shaft serviced less than 1k miles ago
* New Shift linkages rebuilt with OEM and some Poly components
* JHM short shifter - Toy guy short shifter available as well (Old school)
* New slave cylinder
SUSPENSION/ CHASSIS/ BRAKES
* Brand new Michelin Pilot Super Sports (Q4) + the same on the car
* BBS CH wheels in 18x8.5
* OZ supperleggeras in 18x8
* new B6 (black) power steering reservoir
* Newer suspension arms and links
* Newer tie rod ends and *****
* RS4 Avon motor mounts
* RS4 Gearbox mounts
* AWE Drive Train Stabilizer and uprated mount
* Upgraded front and rear sway bars with rear subframe brackets (old school intrax)
* ECS Cayenne BBK - both stock and Pagid endurance pads available
* Stainless brake lines - Front
* H&R Street Coilovers
* Bullet nosed racing wheel studs (long)
EXTERIOR
* RS4 front bumper cover
* M3 Lip spoiler (trunk)
* Euro spec headlights (E Codes - early non dimpled lenses)
* Custom RS4 mesh grill and fog lights (not installed)
* LED conversion on rear plate display (no dated yellow bulbs)
INTERIOR
* AWE center vent boost gauge - matches interior lighting
* Carbon interior trim
* ICE IPod radio integration kit (30 Pin)
* New OEM Audi radio head unit
* New ABT sport floor matts
OTHER
* Gearbox tunnel is heat reflective coated with proprietary heat shielding
* Battery relocated to trunk for better weight distribution. (catch tank and N75 in its place)
*if it says new, it is less than 1k miles of use
*lots of extras and spares not listed but available, I am sure I am missing some items in this list.
This car is currently in Charlotte NC, we can find a way to get it back to the midwest, please email me for further information and I will get back to you as soon as I can. Guthrie.john.s@gmail.com
More pics can be found here,
https://plus.google.com/photos/10318...LPJ_Jy--JS8igE
ID:	411455   Click image for larger version
Old Jan 7, 2015 | 03:13 PM
The_Ruski_Driver's Avatar
The_Ruski_Driver is infamous around these parts
sending to a friend who may be interested!
Old Jan 7, 2015 | 04:21 PM
BLKPEPR's Avatar
BLKPEPR is infamous around these parts
Nicely Done GLWS!
Old Jan 8, 2015 | 07:40 AM
Gewaltakt's Avatar
Thank you guys, It's hard to let her go. Been a great car to me and a complete sleeper
awdbiturbo1
Feb 18, 2016 10:24 AM
I'mAllIn
Sep 11, 2015 06:38 AM
JMon
Aug 21, 2015 08:20 AM
