FS: Mild Build 1986 Porsche 944 Turbo
Year: 1986
Make: Porsche
Model: 918 Spyder
Price: $10500
Mileage: 183000
Color: Guard's Red
Location (State): TN
Transmission: Manual
Drivetrain: Rear Wheel Drive
The Good:
Front Suspension:
Koni double adjustable shocks with M030 threaded collars (coil-overs)
KLA Billet Monoball upper strut mount
Racer's Edge upper hat and lower seat
Hypercoil 350lb springs
Rebuild control arms with lowering race spindle pin
968 M030 updated caster blocks
Turbo S M030 28.5mm Front sway bar with solid center bushings
Rear Suspension:
Koni Coil-overs with Hypercoil 450lbs springs
Racer's edge upper hat and lower seat
18mm adjustable rear sway bar with solid bushings and drop links
Tie down eyes on rear shocks (easy transportation to track)
Misc:
Corner Balanced
Reinforced torsion tube carrier
Aggressive Alignment
Engine:
Rebuilt ~30k ago, at which time the Lindsey Racing 340 RWHP kit was installed.
Rebuilt Head and converted to spring loaded Tensioner within the last month.
Passed Emissions in Hamilton County TN with no issue.
Wheels:
BBS RS 16 x 7's and 8's
Tires:
205/55R-16 Bridgestone RE-11
255-/50R-16 Bridgestone RE-11
The Bad:
Clear is peeling in some areas and paint isn't in perfect shape (rock chips, etc)
Broken Fog Light Cover (Happened unloading car from trailer)
Missing one seat adjustment button
Typical 944 stuff (cracked dash, odometer not working, hatch seal, sunroof not working)
AC condensor is MIA. PO had a new radiator installed but left the condenser off.
Odometer shows ~183K and I do not think that is very far off. PO replaced it with a GT3 and it sat until the HOA decided it should go. A well know 944 mechanic in the Nashville area got it and went through it before I bought it, so belts, water pump, and rollers are all taken care of (new in October)
Overall the car is very solid. I purchased it in October to be my daily driver and in December the stud that the tensioner mounts to gave up the ghost. I had the head repaired and had it upgraded to the later, spring loaded tensioner. In the time that the car was out of commission, I changed jobs and this car won't work for what I need. It drives great, boost feels good, and handles like it is on rails. I have receipts for suspension and engine work that total to around 15K. This would be a great weekend car, DE car, track car, or DD if you don't mind a little more racy ride. The factory sport seats are awesome. Supportive where you want it and cushy where you don't.
I will have some more pictures tomorrow, I ran out of daylight today. I also have a stack of receipts if you want them and am happy to give you my mechanic's name and number to answer any more questions about the car.
I'd consider trading for a 1st or 2nd gen Tacoma but I'm going to be pretty picky on that.
Link to pictures: https://www.flickr.com/photos/637351...57667603228914
ECS Tuning - BMW
Mar 22, 2016 06:52 AM
