FS: Turbo Kraft Front Monoball Camber Plates (996TT/997TT/4WD)
Old 03-12-2019, 10:14 AM
mavila's Avatar
mavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of light
Price: $350
Part fits: Porsche 911 997 Turbo, Porsche 911 996 Turbo
Location (State): CA
Item Condition: Brand New
Turbo Kraft Front Monoball Camber Plate Set for all 996 Turbo/997 Turbo/4WD cars. These were opened but never installed. Rather than continue to spend lots of money on GT3/Cup Car suspension pieces for the ultimate suspension setup, I have decided to invest the money in a Birel or Rotax kart instead. New these are $498; here $350 shipped. From their website (link to Turbo Kraft website: https://parts.turbokraft.com/collections/997/products/front-monoball-camber-plate-set-4wd)
A performance upper strut mount set replacing the original elastic, damper to chassis mounts. Built in position offset allows for an expanded range of camber adjustment progressively based on vehicle ride height. Typically, 1 to 1.5 degrees of additional negative camber adjustment can be achieved. CNC machined billet aluminum alloy, hard anodized. Includes high quality, Teflon lined self-lubricating spherical bearings and zinc plated hardware. Strut shaft hardware kit included for M14 x 1.5 thread type.
Notes:
① Use with Bilstein PSS Systems require PN: 996 343 020 K1 : Spring perch adapter kit.
② Application intended for performance threaded body dampers.
* The Turbo and 4WD models require different special offset mounts for proper suspension geometry. Porsche has no solid bearing mounts for any 4WD models!
Application:
996 Carrera : All 4WD
996 Turbo : All 4WD
997 Carrera : All 4WD
997 Turbo : All 4WD
Old 05-21-2019, 08:16 PM
testdr's Avatar
testdr is on a distinguished road
pm sent
Old 05-22-2019, 07:38 AM
mavila's Avatar
These are sold.
Old 07-14-2019, 05:09 AM
nlcxmoses's Avatar
nlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of light
i purchased them, thanks again for sell.
ctony66
01-27-2018 05:20 PM
VID997
08-28-2017 03:40 PM
VID997
08-28-2017 03:35 PM
rob.boost
04-13-2016 06:14 AM
blackboxster
11-05-2012 04:54 AM
Quick Reply: FS: Turbo Kraft Front Monoball Camber Plates (996TT/997TT/4WD)
