1999 M3 with S54, Full Cage, Low Miles!
Year: 1999
Make: BMW
Model: M3
Price: $28500
Mileage: 79163
Color: Black
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
1999 E36 M3 with S54 swap from a 2005 M3 and 5-speed manual ZF transmission. It’s an extremely quick and reliable HPDE car with the potential to make into a competitive track car. I’m the fourth owner. The second owner had the car built by Turner Motorsports, including the full cage. I had the engine swap performed at approximately 78k miles. The S54 has the VANOS completely upgraded with Besian and Dr. VANOS parts along with WPC coated bearings.
The car has a clean title, clean CarFax, no accident history, and is titled in Texas. I don’t have it registered as I trailer the vehicle. Body is in good shape, no dents, no rust, does have normal track/HPDE patina on the front end and wheel wells. The front bumper cover has some cracks where the front lip pulled away during an off, and I have a new in box aftermarket cover that will be included. The lip is secured currently, and I’ve been using as is for several months with no issues.
Tires and brakes have a lot of life as the tires are scrubs that I have no heat cycles on, and brake pads and front rotors only have 4 HPDE sessions. Car needs nothing to go an enjoy track days today!
DEAL: $28.5K
Aerodynamics
Rieger front spoiler
Hard Motorsports canards
Bimmerworld V3 carbon wing
Mateo Motorsports diffuser
Body
Hard Motorsports rear polycarbonate windows
Turner Motorsports under-panel
Custom sunroof delete by Turner Motorsports
AeroCatch hood latches
Brakes
Brake ducts, 3" hoses, backing plates, Turner steering rack stop
Stainless steel lines (ECS)
Turner brass guides
Hawk DTC-60, only 4 sessions on all 4 corners
New front rotors, only 4 sessions
Chassis
Full weld-in cage, by Turner Motorsports
Turner solid motor mounts
Turner solid transmission mounts
AKG solid FCABs
Turner solid subframe & diff mounts
Drivetrain
Blanton 3.64 differential
Rogue Engineering differential cover
AKG Race Shifter
ZF 5-speed manual transmission
Engine
S54 swap from 2005 M3 with 82,075 miles performed at 78,000 miles
Beisan Systems vanos solenoid coilpack
Beisan Systems vanos seals repair kit
Dr. Vanos C300 exhaust hub
Dr. Vanos stage I noise reduction kit
Dr. Vanos cam-bolt repair kit
WPC coated rod bearings
Turner Motorsports underdrive pulley
RKTunes, 300 whp / 237 wtq
Bimmerworld Stage 2 fuel starvation elimination kit
Fluidyne radiator with Samco hoses
Spal 16" fan
Custom oil cooler & catch can
Moroso aluminum expansion tank
Motorsport 55 degree tstat
Turner Motorsport custom power steering reservoir relocation
Exhaust
Custom section 1&2 with AA muffler
Epic Motorsports stepped headers
Other
Custom driver floor pan by Turner; MKHA passenger floor pan
Turner Motorsports pedal set
350mm Momo steering wheel with quick release
Autometer oil pressure, oil temperature, water temperature gauges
Longacre race mirror
Fiberglass headlight intake duct
Safety
Hard Motorsport battery cutoff with OMP remote cable
Driver window net
OMP halo seat
Schroth Profi II 6 Pt. harnesses
Front and rear tow hooks
Suspension / Wheels
Turner Motorsports race camber plates
Turner Motorsports sway bars (30mm adjustable front and 24mm adjustable rear)
Bilstein PSS9 coilover kit
Turner Motorsports wheel studs
OZ Alleggerita HLT, 17” with Continental scrubs (no heat cycles on tires since purchased)
Pictured, but not included
AIM Solo DL and SmartyCam HD 2.1
Cool Shirt System
Passenger OMP seat
Recent Maintenance
4/1/2017 78,000 S54 swap
4/1/2017 78,000 WPC coated rod bearings
6/18/2017 78,209 Alternator
11/4/2017 78,319 Water pump, Motorsport t-stat, Moroso expansion tank
11/4/2017 78,319 replace oil senders
11/10/2017 78,319 Tensioner, tensioner pulley, belt
11/11/2017 78,319 Oil change
12/2/2017 78,476 brake fluid flush
1/8/2018 78,599 Flex disc, center support bearing, rogue diff mounts
4/1/2018 Transmission swap
04/12/2018 Differential seal
10/14/2018 78,971 oil change, coolant change, brake fluid reservoir gasket
12/16/2018 New battery, new oil pressure sender
12/10/2018 Speed sensor gasket, new starter
1/10/2019 Dyno, 300hp/238tq
1/12/2019 Differential overflow system
3/26/2019 79,172 brake flush, new front rotors, new DTC-60 pads (all 4)
Walk around link: https://i.imgur.com/BS5vq0F.mp4
This is awesome. I'm doing a S54 swap with a 6 speed in my 95 M3 currently. Mine will be more of a street car/weekend track car setup but love the work put into this.
I was also thinking of going e85. I'm told with that setup and a good tune I should be able to reach 330 WHP.
Anyways, not trying to sidetrack this thread. GLWS!
Good luck on your swap... totally worth it. The extra rpms make all the difference. 330 whp will be nice too.
Mine only has headers and tune, so plenty more can be had from it
Originally Posted by truboardr13
This is a Super nice car. I have seen it at the track, and know that the seller is meticulous with all his cars and there maintenance.
Open to reasonable offers. I've got lots of spares that can be negotiated in the deal as well, including:
Second wheels set (Kosei K1)
Conti scrubs
Pirelli wets
PFC 01 pads
Used front rotors
More!
calbobba996TT
Mar 31, 2009 12:23 PM
