LMR Turbo Prototype Race Car (Built 500HP Hyabusa Engine)
Old Aug 27, 2019 | 07:32 AM
swift996's Avatar
swift996 is infamous around these parts
Year: 2015
Make: Suzuki
Model: SX4
Price: $25800
Mileage: 100
Color: Green
Location (State): NC
UPDATE - PRICE DROP $28,000 $25,800
The car is in great working condition with very limited hours on the motor/trans since building it. I have a toddler and another baby on the way. I just won’t have the time to get my skill level up to be fast in this car at this stage in life.
The car was street legal in Oregon. I have a new complete kit uninstalled (aux battery, kill switch, relays, wiring, headlights, tail lights, turn indicators, horn, etc.) to make it street legal again. Rules vary state by state but I could get it street legal in NC without a problem. I don’t see it being an issue in any state but I only investigated in NC where I live.
The body panels have a little wear/use in some areas but structurally are fine. If you are particular there is little repair work to get them showroom new. All the molds, build books, logs, CAD drawings, files, etc. will also be included with the sale. I also have an extra set of 4 brand new Konig wheels with brand new Hoiser tires mounted to them that will be included. The molds (3 pieces) are a tad larger than the car (FYI). The car easily has $70K into it. It’s a great track toy or Radical alternative. With the power, it should be faster than just about anything on the track with a good driver. The power to weight ratio on the high boost setting is similar to an Indy Car.
I also have a ~1.5yr old 22’ V-nose enclosed trailer w/ winch (wireless remote controlled) that can be included for an extra $4K.
Specs
  • Power 275 HP on 8PSI (500HP on 18PSI)
  • Weight 1050 LBS
Chassis
  • 4130 Cro Moly Tubing (CNC routed for precision fitment)
  • FEA analyzed & designed structure
Body
  • 3-Piece removable carbon fiber with foam resin infusion (CFD analyzed)
Engine
  • Has 2.5 hrs of track time (~4 hrs of dyno time)
  • Fully Built - Gen 1 Suzuki Hyabusa Engine
  • 9:1 compression ratio
  • Forged Carrillo pistons/rods (pistons have teflon and ceramic coatings)
  • Custom head - Upgraded head work with valves and springs
  • Roller Cam Chain Conversion
  • Proboost Turbo Kit with Intercooler (Holset HX35 Turbo)
  • Custom CNC machined racing oil pan
  • Microtech tuning module
  • Adjustable boost controller (also has push to pass button with higher boost profile)
  • Accusump with turbo oil scavenging system
  • 421WHP @9200rpm / 250TQ @ 7500 on 18 PSI
  • 230WHP @9200rpm on 8 PSI
  • Runs on 93 pump gas but run C16 mix for extra safety on track
  • Set-up is capable of 500whp, all top quality thru and thru on the engine build
Fueling
  • 8 Gallon Fuel bladder
  • Fuel lab regulator
  • Pick up pump and high pressure pump
Transmission/Driveline
  • Pro-Shift paddle shifter with "no lift shift" and auto blipper
  • Custom dry clutch (capable of 800hp)
  • Custom grinded up/down gears
  • Torsen differential
Brakes
  • Wilwood 4 piston
Suspension
  • Adjustable Ohlins - Indy Car
  • Nine way adjustable suspension rockers
Wheels/Tires
  • Konig 15x8, 15x9
  • Hoiser Slicks 245/40/15
Safety
  • Spa Fire System
Interior/Instrumentation
  • Momo steering Wheel
  • Pedal assembly - Tilton with multi place adjustment
  • Aim MyChron 3 Gold XG Log w/ 5 channel acquisition
More Pics: eBay item 264444401729
Old Sep 18, 2019 | 07:20 AM
swift996's Avatar
update - price drop$28,000$25,800
Old Jan 5, 2020 | 09:40 AM
swift996's Avatar
Price Drop to $19,800.
I have another baby coming in a few months and am trying to get things cleaned up and organized. A fun toy for someone who likes fast things!
Old Jan 5, 2020 | 12:00 PM
Kendall993's Avatar
Kendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to behold
This is a lot of fun for under 20K! GLWS
Old Jan 5, 2020 | 02:38 PM
ukrbmw's Avatar
ukrbmw is infamous around these parts
What kind of times did you get at VIR? Looks very fun!
Old Jan 5, 2020 | 07:41 PM
swift996's Avatar
It's a pretty short history. I purchased it back in May of 2019 with the idea I'd want something purpose built. Was looking at Radicals but was intrigued by the performance of this one and didn't want an ancient Radical (all I could afford in my budget). I only took it out to one track day and was pretty slow as it was my first time in the car, learning it, etc. I picked up things in later sessions but didn't even bother logging since I was just feeling out the car. Since then, I had a slew of travel, things picking up at the office and found out my wife was pregnant. She already hated this purchase but with a toddler and another one coming, I don't see myself having time to play with this thing.
pd0019
Jul 9, 2016 03:59 PM
ace32x
Feb 24, 2016 11:00 AM
02vtecsir
Jul 3, 2015 07:20 AM
gnx7
Jun 14, 2012 03:14 PM
94Silver
Apr 19, 2006 12:59 AM
