2011 E92 M3 Blue Santorini 6MT Supercharged
Old Jan 27, 2020 | 08:31 AM
NC Rider's Avatar
NC Rider is infamous around these parts
2011 E92 M3 Blue Santorini Wrap 6MT Supercharged with $62k in Mods
Year: 2011
Make: BMW
Model: M3
Price: $36000
Mileage: 86700
Color: Blue Santorini
Location (State): NC
Transmission: Manual
Drivetrain: Rear Wheel Drive
***NO LONGER FOR SALE***
I wanted to build an exceptional M3 for showing off to my BMW enthusiasts, the local BMW CCA and represent the BMW brand at area car shows. What makes this track-inspired car different from the rest of the M3s for sale? ESS custom tuned supercharger, 20" wheels and tires, MagnaFlow exhaust, brand new Santorini Blue wrap over its original and excellent condition Alpine White factor paint, Alcantara interior upgrades, Recaro seats, and $31,000 (documented) of new parts (within the last 1.6k miles). All three (3) recalls have been performed on this car: PRA 2013/13476, PRA 2018/16803, and PRA 2018/16813. And unlike a lot of other cars for sale on this site, I have no problems showing the clean underside of this car with its new felt and metallic debris shield as under my ownership, it has never been driven in the rain or snow.
I think that the discerning buyer should determine from the video, pictures (see link below) and my description if the car is in immaculate condition and if the recent upgrades (less than a year) are worth the extra money in negating the miles. You should know that, regardless of this E92 M3's mileage, the owner needs to be prepared to show objective evidence indicating that they have maintained the following items on this particular model: RBCs, Oil Separators, Spark Plugs, Valve Cover Gaskets, O2 Sensors, Engine Mounts, New fluids for engine, transmission, and brakes, windshield wipers, sway bar bushings, DCT seals if automatic - otherwise new clutch and flywheel if 6MT, steering rack boots, underfloor felt, and battery. The aforementioned parts and labor can equate between $15k to $20k in costs if you think that you are getting a good deal. And don't forget to factor in the down time and recurring annoyances associated with taking the car in for repairs and then picking it up. You won't need to be concerned with these issues if purchasing this car. This car has never been in an accident and I have a recent CarFax report. A new windshield was installed, as I did not like looking at small rock chips. It comes with two OEM BMW Key Fobs.
I had the car re-coded European so that the TPMS codes work more reliably. In addition, the car was recently coded GTS Euro MDM making the "fun" factor around corners off the charts!
I can provide an Excel file with color coding and costs of all of this car's modifications. Just send me a PM with your personal email. Additionally, I have prepared a 3-ring binder of all of the receipts for the new parts and some receipts from the previous owner. And yes, all vinyl stickers can be easily removed from the windows by the new owner and no, I am not accepting any trades nor will I sell any part individually. Located in Greensboro NC. No codes whatsoever in this car - note that on average, an E92 M3 throws 12 codes.
SUMMARY (see picture with options)
Premium Package (0ZPP)
Technology Package (0ZTP) (iDrive, M drive, electronic damping control, comfort access)
Competition Package (0ZCP, 07MA)
Enhanced Premium Sound (0752)
Carbon Leather Interior Trim (04MY)
Comfort Access Keyless Entry
Carbon Fiber Roof
iPod and USB Adapter
Recalls performed: Airbag, Battery Cable, and Motor Blower Wiring
Mileage: 86,XXX
Horsepower Crank: 625
Torque: 364 ft-lbs
VIN: WBSKG9C58BE367887
ENGINE
ESS 625vt2 Supercharger with Custom High Heat White Powder Coated Cover (Active Autowerke installed)
VFE Oil Cooler (Active Autowerke installed)
Bosch Upgraded Injectors (Active Autowerke installed)
Custom Catless Full Exhaust with two Magnaflow Mufflers
New ESS Custom Tune (includes software, 8600 rpm limiter, patented OBD, and adapter cable)
New RBC WPC Treated; re-assembled with upgraded ARP hardware
New Engine Mounts
New O2 sensors and correct software upgrade for no codes
New NGK Laser Platinum Spark Plugs and Install
New Super Charger Oil and Service
New Oil Change
New Valve Cover Gaskets
New Pinion Shaft Seal
New BMW Oil Filler Cap
New BMW Power Steering Reservoir and Clamps, PS Flush
New BMW Inlet Duct
New White Powder Coated (to match the ESS Injector Cover) Valve Cover, Seals, and Gasket
New GTS Euro MDM Coding, RPM coded to 8600 redline. And New "Shift Booster"
New OEM Oil Separators, O-rings, gaskets, and torx fasteners
DRIVETRAIN & BRAKES
BCr Coilovers with 30 position Dampening Adjust and Camber Plates
Upgraded Control Arms
ECS Stage 2 Rear Disc
Turner Motorsport Full Polyester Sub-Frame Mounts all around
Turner Motorsport Full Solid Rear Differential Mounts
New Ground Control Adjustable Sway Bar Links
New Front BMW Brake Pads, Rotors, and braided stainless steel lines
New BMW Clutch and Flywheel
New Differential Oil
New BMW Anti-lock Brake ABS Dynamic Stability Pump
ECS Performance Clutch Fork Pivot Pin
New BMW Steering Rack Boots
New BMW Rear Wheel ABS and Speed Sensor and Installation w/ TPMS Clear
New Sway Bar Bushings
New Clutch Stop
New Castrol React SRF Racing Brake Fluid
EXTERIOR
IND Color Matched Side Markers
BMW Performance Rear Spoiler
MTEC Rear Carbon Fiber Diffuser
BMW LED turn signals
Genuine BMW Black Chrome Side Grills
Custom OSS Headlights
LCI LED Taillights
New Carbon Fiber AeroCatch hood covers
New BMW Carbon Fiber eyebrows
New Vacuumed-Dry Carbon Fiber mirror covers
New IND Carbon Fiber Kidney Grills
New Carbon Vor Style Front Lip Spoiler
New BMW Puddle Lights
New Bosch Wiper Blades
New Turner Motorsports Stainless Steel Skid Plate
New BMW Center Underfloor Coating (felt)
20" WHEELS & TIRES
New 20x9 (+25mm) Gloss Black AXE EX18 5x120, 20x10.5 (+25mm) Gloss Black AXE EX18 5x120
New Hankook Ventus V12 P245/30/20, P285/30/20 Hankook Ventus V12 (800 miles on them)
New BERU HUF TPMS on all four wheels
New European TPMS Coding and all S/W updates
New BMW 68mm Center Caps
New 78mm MotorSports Hardware bullet stud conversion
INTERIOR
AEM Gauges on AEM Center Console (Boost, AFR, Oil Pressure)
BMW Performance Steering Wheel
Alcantara Interior: Pillars, Center Console, handbrake, shifter, and ceiling
Recaro CS, Leather sides, Alcantara Centers with 1/2" risers
BMW Performance Carbon Shift **** with Alcantara Boot
BMW Performance Carbon Handbrake
BMW Dark Black Metal Pedals
Interior LED lighting upgrade (map and dome lights)
New Custom Stainless Steel Mounts for Seat Height Adjustability in 1/2" increments
New Footwell FRM Module and Updated Software Programming
New/Updated Navigation System maps
New Fit System RM011 Clip-on Wide Angle Rear View Mirror
New Upgraded Battery
There are no wheel spacers on this M3; this car has the correct hub-centric hubs for a "vibration free" ride, even at high speeds. All of this vehicle's underbody felt, with hanging issues from the previous owner, have been replaced by either new OEM felt along with upgraded fasteners or the new Turner Motorsports aluminum debris shield. I possess all receipts done since December 2017 (when I purchased the car, neatly organized in a 3-ring binder) and all upgrades, maintenance, and modifications are summarized in an Excel file as well as this accident free vehicle's CarFax (both can be provided electronically). The Recaro seats are extremely comfortable and I have added ½ x 1 inch stainless steel side rail spacers to accommodate short or taller drivers.
I can assist with shipping the car to you with your selected carrier of choice. The local international airport is only 15 minutes from my house and I will gladly come pick you up if you would like to fly in for a test drive. In addition, I can assist you with contacting a local and reputable BMW mechanic for a pre-purchase inspection (PPI).
I read on another forum that the OEM clutch and rear diff can handle upwards of 800+ hp at the flywheel so the new OEM’s clutch coupled with ESS Tuning's 625 is approximately 20% under the maximum specifications in this critical area.
The car, when not being driven, is attached to a battery charger in its heated and air conditioned garage.
The ESS supercharger had an updated tune to it a few months ago along with its scheduled 2,000 mile oil change.
Old Jan 29, 2020 | 02:36 AM
NC Rider's Avatar
For those who have asked to see this car in its original Alpine White paint color, which is perfect by the way, please click on this video:
Old Jan 29, 2020 | 08:39 AM
Kendall993's Avatar
Kendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to behold
This is an amazing build and one hell of an ad!! Great write up!! Seems like all the documented issues have been addressed so the new owner should be able to truly enjoy this car worry free!! GLWS
Old Jan 29, 2020 | 11:00 AM
3rdpedalrequired's Avatar
3rdpedalrequired is infamous around these parts
Kudos to the Seller for taking the time to post such a detail oriented ad. Beautiful M3!!! GLWS
Old Jan 30, 2020 | 05:05 AM
NC Rider's Avatar
Thank you for the compliment on the ad. I tried to take all of the typical worries out of the private buyer's thoughts when I made the ad and answer as many questions as possible so that the reviewer wouldn't be bored thumbing through the pictures and want to see and/or read more about what this car offers so that they can more easily compare it to another similar model.
NC Rider's Avatar
Thank you
Old Feb 5, 2020 | 04:23 AM
NC Rider's Avatar
bump for a truly unique car...
that has great maintenance records and is mechanically and aesthetically near perfect. Of note, its exterior color, although being a high-end wrap with a near perfect RGB color match to Santorini Blue, makes this car the only Santorini Blue, Left-Hand drive, 6MT, supercharged E92 M3 in North America. There were only 22 Santorini Blues made by BMW of which only 8 came to North America as Left-Hand drives. And from my discovery of, only one of these eight was a 6MT and it currently is in a stock configuration.
Old Feb 11, 2020 | 04:47 AM
NC Rider's Avatar
Bump for a price reduction and a configuration change
Old Feb 11, 2020 | 11:17 AM
Audi R8's Avatar
Audi R8 is infamous around these parts
This is actually a quite nice build here.... I loved my e92 m3. This was tastefully modded.
Old Feb 13, 2020 | 09:00 PM
NC Rider's Avatar
Thank you for your comment
much appreciated
Old Feb 14, 2020 | 09:08 AM
Cummins990's Avatar
Cummins990 is infamous around these parts
This is so tempting! Great Ad!
Old Feb 15, 2020 | 03:11 AM
NC Rider's Avatar
Pull the trigger and make some additional inquiries...
Old Feb 23, 2020 | 02:31 PM
NC Rider's Avatar
bump???
Old Mar 3, 2020 | 08:25 AM
NC Rider's Avatar
TTT for a great buy
eclou
Other British Cars
Sep 30, 2014 04:36 AM
Curt2000
BMW //M
15
Oct 15, 2013 12:46 AM
Global Autosports
BMW Vendor Classifieds
Aug 16, 2012 02:14 AM
