Bentley Continental GT Immobiliser problem
Hello @Renegade123 ,
Welcome to 6speedonline !
As to your issue, is there anything that you can tell us, any prior faults, any water/rain damage, any wet carpet, as the KESSY module is located under the carpet on the left front floorboard, any damage to the keyfob, did it get wet at all, is the battery in the fob good, does the fob light blink green when you press any of its buttons, do you have a scan ?
I see that the instrument cluster trim is removed, what is the issue there, has the steering column been worked on, or replaced ?
Johnny
Johnny
@Renegade123 ,
What year is your GT, are you inserting the key-blade into the ignition switch, or using push button start, does the instrument cluster power up at all, did you try the second keyfob ?
Is your keyfob working by keyless entry, or by the pressing of fob buttons to lock and unlock the doors ?
I take it by your picture, that the engine is not starting and running, or, is it starting and stalling after 2 seconds ?
Do you have a Ross-Tech VCDS or ODIS VAS 5054 scan ?
Johnny
Johnny
