2012 Flying Spur Alarm Sounder Location
Old May 30, 2026 | 04:00 AM
dan_h's Avatar
dan_h
I have had my car scanned with VCDS and get these faults
2 Faults Found:
01134 - Alarm Horn (H12)
000 - -
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
012 - Electrical Fault in Circuit - Intermittent
Not too bothered about the mirror as it seems to function properly but I would like to replace the alarm horn as I have heard if the battery goes flat in the alarm horn it can cause main battery drain.
Does anybody know where the sounder is located on a 2012 Bentley Continental Flying Spur?
I have read about people replacing the onboard battery in the sounder but you have to solder it, does anybody have any insight on replacing the battery?
Old May 30, 2026 | 09:46 AM
jeyjey's Avatar
jeyjey
It moved from under the front scuttle to behind the left rear wheel arch liner at some point. I know by 2015 it's behind the wheel liner, but I don't know the exact date it moved.
Yes, you can solder a new battery in, but at 14 years I'd say it's highly likely that it has already leaked and damaged the circuit board.
dan_h
Bentley
May 22, 2025 05:13 AM
ginogordos
Bentley
Mar 17, 2022 08:56 AM
tqd7mb
Bentley
May 13, 2019 03:15 PM
Buddy123
Jul 6, 2018 01:25 AM
jgjones
Bentley
Mar 23, 2016 08:33 PM
