Boxster S track prep- pads, fluid n tires
Old Oct 8, 2010 | 06:21 PM
scottfromnapa's Avatar
scottfromnapa is infamous around these parts
Been 1.5yr since I had my 2000 Boxster S on the track. Got some MPSC rubber on and cant remember what I used for starting cold tire pressure and the optimum psi for sticky time. Could use some input.
Also just swapped my toasted front OEM pads for another slightly used set and was thinking of going with more bite-pagids, others?
Also due for brake fluid swap, last time I think I used Motil Blue, any suggestions there. Thanks in advance for any experienced advise
Old Oct 9, 2010 | 12:55 AM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
i haven't used MPSC so can't comment on that. I use pagid yellows with great success on a Cayman. Motul 600 for brake fluid. combined with ss lines, no fade at the track at all. good luck!
Old Oct 12, 2010 | 09:39 AM
wingnut2u's Avatar
wingnut2u has a spectacular aura aboutwingnut2u has a spectacular aura about
It has been a while since I ran my MPSC but if memory serves me correctly I started at 28psi cold and ended up at 35psi when I came off the track
The Pagid Yellows are great pads, expensive, and more importantly I don't think there are any sets left in the US
I ran the Hawk HT-10 pads my last time out and there was not a noticeable difference between those and my Pagid Yellows. Plus the Ht-10s are a much better price. You may want to also look at the Pagid Orange pads.
Old Oct 15, 2010 | 08:33 AM
driver8's Avatar
driver8 is infamous around these parts
This should help with pressures and temps.
http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
audipwr1
Sep 25, 2021 01:31 PM
2lflat4
Nov 18, 2019 05:05 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
Just Cruise
Aug 25, 2015 12:39 PM
