VW Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
:: ECS Tuning :: Stage 1 Rear Big Brake Kit - VW MKIV 337/20th/R32/GLI - Click Here !
Old Aug 27, 2013 | 01:07 PM
ECS Tuning - VW's Avatar
ECS Tuning - VW is infamous around these parts
Click HERE to order or for more information.
Stage 1 Rear Big Brake Kit - VW MKIV 337/20th/R32/GLI - $599.95
If you've pumped up the power under the hood of your MKIV, there's nothing like a little added deceleration to keep you out of the weeds.
Step up from stock cast iron 256mm rear rotors to 306mm, two-piece Tru-Float rotors. Durable and good looking, these ECS Tuning-engineered rotors combine lightweight anodized aluminum hats with vented, cross-drilled and slotted cast discs. Mount them easily, using the kit brackets and included hardware.
Add our Exact-Fit brake lines and brake pads of choice for an arresting rear brake upgrade that slows your car with authority... and style.
Old Sep 3, 2013 | 09:45 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
