:: ECS Tuning :: VW 337/20th/GLI ECS Aluminum Coolant Split Pipe - New Item !!!
Subscribe
Jun 3, 2014 | 11:24 AM
Click HERE to order or for more information.
VW 337/20th/GLI ECS Aluminum Coolant Split Pipe - $24.95!
Plastic coolant connections are consistently subjected to heat shock, corrosive substances, and chemical degradation. Considering the importance of adequate engine cooling, coolant fitting upgrades are always a wise investment.
ECS has brought you a cast-aluminum replacement for the plastic coolant split pipe on the MKIV 1.8T.
This highly failure-prone fitting can be responsible for a sudden, major coolant leak – over-heating engine internals, causing catastrophic damage.
The ECS coolant split pipe will withstand excessive abuse, restoring faith in your cooling system.
ecs600header.jpg   VW_337_20th_ECS_AluminumSplitPipe.jpg   VW_GLI_18T_ECS_AluminumSplitPipe.jpg
Reply
