VW Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
:: ECS Tuning :: VW MK6 Jetta 1.8|2.0T Gen3 ECS Boost Tap & Gauge Kit - Click Here !
Old Nov 5, 2015 | 12:58 PM
ECS Tuning - VW's Avatar
ECS Tuning - VW is infamous around these parts
Click HERE to order or for more information.
ECS believes your boost gauge should be easy to see, blend with your interior, and provide you with the most accurate readings at all times.
Other methods of acquiring a boost/vacuum signal can lead to skewed data being sent to your ECU, ultimately dropping engine power.
Engineered specifically for the Gen3 engine, we designed our Throttle Body Boost Tap with 2 ports and our Manifold Port Boost Tap with 3 ports, so you have multiple options to provide the strongest manifold signal. You can be certain that all critical data is not affected and your engine's power is not lost.
ECS Tuning - VW
Nov 5, 2015 12:16 PM
ECS Tuning - VW
Nov 5, 2015 10:49 AM
ECS Tuning - VW
Nov 3, 2015 11:25 AM
ECS Tuning - VW
Oct 30, 2015 01:52 PM
ECS Tuning - VW
Oct 30, 2015 12:59 PM
