VW Touareg, Phaeton, R32 and other VolksWagen's
Question re: electrical
Old Jun 25, 2015 | 09:55 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
My son has a 2000 VW GTI Mk 4. Up until a few days ago, the car started great. Then only the BATTERY light on the dash popped up. No check engine, no nothing. All electrical shut down except for the battery light. Replaced the ignition switch. Car started fine for about 4 days then back to not starting and just the battery light on. Tried tapping the brake with the ignition turned to "ON" and all the dash lighting came on and car would start but as soon as you took your foot off the brake pedal the engine quit. No electrical, no nothing. Has anyone else experienced this problem? If so, what was the fix? Thanks.
Old Jun 25, 2015 | 04:35 PM
Pors-Vette's Avatar
Problem solved for now and hopefully for good.
I figured if it was an electrical problem it could mean a short in the system or a bad ground. Found that by pulling and wiggling the negative cable that power would be restored. Took off cable end that attaches to the engine and cleaned it. Re-installed it and power back on. Something as simple as that.
Old Oct 5, 2015 | 03:46 AM
Jackracing's Avatar
Jackracing is infamous around these parts
Very sorry for this problem, I had not such experience.
cnebrask
Oct 3, 2024 08:19 PM
powerbeautysoulAM
Carrera GT/918
Aug 31, 2015 02:59 AM
The Oss
Aug 24, 2015 08:19 PM
JMon
Aug 21, 2015 08:20 AM
