Wider tires than these on a 03 C4S?
SubscribeI have pzero 305/25/19s on the back, fronts are 235/35/19s
These are the wheels:
http://mhtwheels.com/wheel.cfm?cat=215
If you're asking if larger tires will fit without rubbing, it will depend very much on the width and offset of the wheels you plan on purchasing, not just the make/model of the wheels.Originally Posted by 996c4s_dallas
I have pzero 305/25/19s on the back, fronts are 235/35/19sThese are the wheels:
How did you get the C4S emblem with a red "s"? Mine is silver.
You may be able to go with a new 325/30-19 Michelin Sport Cup but you will need a more positive offset adjusted in the rims or spacers.
Try this first though: http://www.miata.net/garage/tirecalc.html
The S logo comes off with a blow dryer and some dental floss. Home Depot sells Rubber Maid "Apple Red" plastic spray paint...a perfect match. Let it dry 48 hrs and re-apply.
PM w/questions.
PM w/questions.
