Wheels/Tires
Tyre size Question
Old Nov 1, 2007 | 11:07 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Tyre size Question
I have changed my front width wheel size on the car, but I'm a little bit concerned incase I have issues with different rolling diameters as I have a the Tiptronic 996 Turbo.
The new width is 8.5" compaired to 8" (rears are still same) but my new front tire size will have to be a 255/35/18 compaired to 225/40/18 does anyone know if this is ok to run alongside the stock rear size?
Old Nov 1, 2007 | 11:26 AM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
The 225's are 25.08 inches in diameter. The 255's are 25.02 inches in diameter. As long as you're not rubbing anything when you turn the wheel or compress the suspension, you should be fine.
Old Nov 1, 2007 | 07:06 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Don't guess.
Know for sure.
Live with the following: http://www.miata.net/garage/tirecalc.html
Old Nov 5, 2007 | 12:11 AM
auto-xr's Avatar
auto-xr is infamous around these parts
My friend is running 255s up front on his 996 c4 w/8.5" fronts. The 255s fit w/no problem but I'm not sure if he rolled his fenders. What's your offset? Also, if you're really concerned, you could go with 245/35/18.
Old Nov 5, 2007 | 11:27 AM
Gcalo's Avatar
It's a bit dangerous to screw with guessing tire sizes especially with the newer traction control systems.
use the tire size calculator and go as big as you want but get it to match OEM diameter specs.
Wrong rear tire sizes can throw off gearing as well.
Do it right!
Old Nov 5, 2007 | 11:54 AM
auto-xr's Avatar
Do it right!
Not guessing here. The 996 was designed for a wheel diameter of 25".
Front:
225/40/18 = 25.1"
235/40/18 = 25.4"
245/35/18 = 24.8"
255/35/18 = 25.2"
Rear:
265/35/18 = 25.3"
295/30/18 = 25"
315/30/18 = 25.5"
If he goes with 245/35/18 or 255/35/18 he's good. The key is to keep the difference from stock to under 3%.
Go to this link to verify for yourself.
http://www.1010tires.com/TireSizeCalculator.asp
BTW my friend is running 255F/295R with no problems. He says that the extra width up front helps with the awd understeer. In addition, if you interested, check out the gt3 forum on rennlist. There are some guys running front widths as high as 285. Not saying that I'd do this, but I thought it was interesting. Hope this helps.
Old Nov 5, 2007 | 11:57 AM
Gcalo's Avatar
Front:
225/40/18 = 25.1"
235/40/18 = 25.4"
245/35/18 = 24.8"
255/35/18 = 25.2"
Rear:
265/35/18 = 25.3"
295/30/18 = 25"
315/30/18 = 25.5"
If he goes with 245/35/18 or 255/35/18 he's good. The key is to keep the difference from stock to under 3%. Go to this link to verify for yourself.
You are close to all of those but the tire calculator I listed will tell you exactly and give the differential.
Oct 6, 2015 05:20 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 06:34 AM
ModBargains
Aug 20, 2015 12:28 PM
