Wheels/Tires
Best size wheels and tires for performance?
Old Jan 1, 2008 | 02:18 PM
cdaniels's Avatar
cdaniels is infamous around these parts
I have a year 2000 996 with 18 inch wheel. front is 7.5 inches wide and the rear are 10 inches wide. I'm not happy with how my car tail wags when manuvering at speeds above 60 to 70 mph....it's scary....I think wider wheels
and lower profile tires would make the car handle better and be less scary at speed....I do have the X74 suspension package and that is a terrific improvement.
Any reccommendation on wheel size and tire sizes? this is a street car only....Thanks
Old Jan 2, 2008 | 05:11 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
Tires are key to handling.Try a Michelin PS2.
Old Jan 8, 2008 | 12:11 PM
glowone's Avatar
glowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to behold
tires
What kind of tires are you running?
There should be nothing scary at 60-70mph that would need anything over stock.
I would suggest finding some stock rims and tires and see what you get. No sense in spending a bunch on new wheels when that is most likely not the problem.
Old Jan 9, 2008 | 04:29 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
You should check to see if your wheels are bent or damaged first.
Old Jan 9, 2008 | 07:46 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
Sounds like you are in need of a good alignment as well. The car is a little squirrely but not at those speeds. Check your alignment specs and make sure its good. Tires won't make your car feel squirrely like you are describing.
COBB Tuning
Jan 1, 2025 09:02 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
WheelB
American Muscle
Aug 24, 2015 08:42 AM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
