Wheels/Tires
265/35 or 275/30 Tires on 19x11 Wheels
Old Apr 5, 2008 | 11:59 PM
suneet's Avatar
suneet is infamous around these parts
Hey guys,
I was wondering if anyone here has experience with putting a 265/35/ZR19 (Michelin or Bridgestone N-spec) tire on a car with 19'' wheels?
The recommended largest rim is 10.5'' but Tirerack's website says even OE's sometimes choose tires for wheels that are a half inch too large or too small without any adverse effects.
Another question... I have a pair of Bridgestone RE01R's in 275/30/19 and the recommended largest width for those tires is 10'', which I find strange. Pirelli makes the same size tire in the Rosso and approves 11'' width. 275mm is almost 11'' so I find it strange... but don't want to stretch an inch away from the recommend rims. What do you guys think?
To explain my situation... I'm actually a Cayman owner, but have fitted some 11'' rear wheels from a 997 wide-body but would like to keep 265mm rear wheels, or use my Bridgestone RE01R's with 245mm fronts, to try and minimize understeer.
I appreciate any input on this.
Thanks,
Suneet
Old Apr 6, 2008 | 04:25 AM
YSS's Avatar
YSS
YSS is infamous around these parts
275 is too small on an 11" rim
put it on and you will see how strecthed it is. i tried a 295 on a 12" rim and it was way too stretched. folow the range on the recommendations.
you need a 295 on an 11" rim.
some 275's are bigger thn others and some have bigger sidewalls but i dontt hnkany will work on an 11" rim
porsche ran 18 x 11 OEM on the 996TT - with an 11" rim. and Porsche are generous with rim widths.
Old Apr 6, 2008 | 10:06 AM
suneet's Avatar
Originally Posted by YSS
275 is too small on an 11" rim...
some 275's are bigger thn others and some have bigger sidewalls but i dontt hnkany will work on an 11" rim.
Well... Michelin PS2 and Bridgestone Potenza RE050A 275/35 are approved by the manufacturer to fit fine on 11'' wheels if you look at the specifications. And 265 is approved up to 10.5... It's just Tire Rack's comment that often you can go .5'' over or under these ranges without adverse effects that makes me wonder if 265/35 can fit too.
- Suneet
Old Apr 7, 2008 | 11:06 PM
themperor's Avatar
themperor is a jewel in the roughthemperor is a jewel in the roughthemperor is a jewel in the roughthemperor is a jewel in the rough
suneet,
Can you really get 265's on a 10.5" rim? I have Carerra S wheels on a boxster (9.5) and want to go 10.5 aftermarket. I didn't think the stock 265 could fit (stretch).
Old Apr 7, 2008 | 11:54 PM
suneet's Avatar
Yes, it's approved for all the N-spec tires at least, as long as your sidewall ratio is at least 35.
Unfortunately my deal for the 11'' rear wheels fell through and this topic isn't relevant for me anymore...
I am in the market for Cayman/Boxster fitment Turbo wheels if anyone is selling.
Old Apr 10, 2008 | 05:32 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Using the wrong rim width can have disastrous results!
Look at the tire manufacturer's recommended widths and stick with those.
Old Apr 11, 2008 | 10:15 AM
damon@tirerack's Avatar
Moderator
I have NEVER said it was OK to put a 265 on an 11" rim. 275 absolute minimum, and only if the manufacturer of the tire says it's OK. 285 is ideal minimum.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Apr 11, 2008 | 10:17 AM
Moderator
Originally Posted by suneet
Hey guys,
I'd like you to show me where our website says it's OK to ignore the manufacturers recommended rim range please. If it does it was a mistake that needs to be fixed.
damon@tirerack.com
Or use this link:
Old Apr 16, 2008 | 09:59 AM
nevaland9's Avatar
nevaland9 is infamous around these parts
ive got 265/30s on a 11.
Old Apr 16, 2008 | 11:45 AM
ahavams's Avatar
ahavams is infamous around these parts
Looking good! Love the Equips
I guess I shouldn't even bother posting a pic of my 235/40/18's on my 18x12 wheels
Old Apr 17, 2008 | 07:47 PM
mkk62's Avatar
mkk62 is infamous around these parts
suneet
try naples porsche dealer just talked with them and they have a bunch of 996 turbo and carrera take offs for cheap...239-280-5144 as for Justin ...
i myself looking for 18's for my 997s with ceramics for r compound tires for the track..
19's hard to find good r compounds
GL
mk
Enemy
Nov 10, 2015 08:01 AM
COBB Tuning
Nov 9, 2015 08:02 PM
oufan2929
Nov 8, 2015 08:26 PM
Zero911
Aug 24, 2015 06:51 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
