Wheels/Tires
Max Rear Tire for 996 NB
Old Mar 26, 2009 | 09:02 AM
craig3887's Avatar
craig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud ofcraig3887 has much to be proud of
I have a set of sport design wheels, same ones on the earlier euro gt3, and want to know the max tire I can comfortably fit in the back. The back rim is only 9" wide. The local tire shop said they could fit 285/30/18 but what I have found from the tire manufacturer's websites is that 285s should be put on 9.5"-10.5" rims. Any suggestions on size and a good brand of tire that can handle DE/autocrossing as well as the street?
Old Mar 26, 2009 | 09:19 AM
damon@tirerack's Avatar
Moderator
On a 9" wheel you should go no bigger than 275/35. 285's are too wide unless the wheel is a 10"
Can you get 285's on a 9" wheel? Sure, if you want to do things with the "bigger hammer" mentality. But in doing it you will be overstressing the tires construction. That causes heat and heat causes lots of other bad things.
Can you? Yes. SHOULD you? No way....
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Mar 26, 2009 | 10:30 AM
Steve's 996's Avatar
Steve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud of
Damon knows his tires.
Old Mar 27, 2009 | 12:53 PM
c2mojo's Avatar
c2mojo is infamous around these parts
a 9" rear on a 996? Seems wrong for sure
Old Mar 28, 2009 | 04:20 PM
bexs996's Avatar
bexs996 is a jewel in the roughbexs996 is a jewel in the roughbexs996 is a jewel in the rough
I have a 295 30 19 on a 19x10.5 at a 52mm offset! But you can go 305 30 19 on a 19x11 at a 65mm offset! What im trying to say is i would go wider!
2lflat4
Nov 18, 2019 05:05 PM
oufan2929
Nov 8, 2015 08:26 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
The Oss
Aug 24, 2015 08:19 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
