Wheels/Tires
24 inch rims from a Full Sized RR to a Sport??
Old Dec 28, 2009 | 12:02 PM
ThunderCat's Avatar
ThunderCat is infamous around these parts
Hey fellas I was wondering if you guys would have the answer to this question?
I am about to take 24s from a full size RR and put them on my Sport. I had staggered Stanced 22's on my Sport first, with 285/35/22'S. Will the front wheel on the 24 still lock up right with my hub, even if it is already a reversed rim, and not standard?
Also will my 295/30/24 inch tires rub?
If worse comes to worse would I be able to run 305/35/24's in the back, and 275-285/30/24's in the front?
Thanks for the help.
GOD BLESS.
Old Dec 30, 2009 | 07:09 PM
NUTEKWHLS's Avatar
NUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the rough
GOD BLESS.
Application for a full size Rover and sport are essentially the same, both are PCD 5x120, and the C/B is 72.6...identical to BMW. Both the full size and sport have BREMBO brakes stock on the supercharged models...if you have a SC version you will want to fit check the wheels for the brakes if the RR they came off did not have them. As far as tires, you should be able to run the same rubber, but you may encounter the need to trim the plastic on the inner fender well? Personally I prefer 22's vs 24's on the Rover...the 22" application performs much better and offers a bit more sidewall on the tires for functionality for daily driving.
I hope this info is useful
Jimbo
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
