Wheels/Tires
Carbon Fiber Products
Old Jan 13, 2011 | 03:18 PM
NUTEKWHLS's Avatar
NUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the roughNUTEKWHLS is a jewel in the rough
License Plate Frame:
Made from 2 mil thick carbon fiber composite material and features an attractive hand polished clear coat that enhances the carbon fiber weave. Frames are available in four different frame styles, choose from two or four mounting holes in Plain Slimline, or Custom Nameplate frames that can feature your company logo or message. Custom nameplate style frames feature a clear polyurethane dome to enhance as well as protect the graphics from U.V. exposure. Our unique frame design with open corners does not block registration tags in all 50 states. All frames come with matching finish hardware hider caps that protects your hardware while adding a finish look to your frame installation.
Keychain:
Made from carbon fiber composite with stainless steel components. Each keychain is approximately 5/16" thick and features a clear polyurethane coating to enhance the beauty of the carbon fiber weave. Keychains are available in plain or a custom screen print that can feature your company logo or message.
Tire Valve Stem Cap:
Made from ABS in Satin and Black finishes , each cap features a carbon fiber composite clear coated emblem to complement your rims or tires. Fits all standard automotive air valves and are compatible with most Tire Pressure Monitoring Systems (TPMS), and because they are so light, they will not affect tire balance. All caps feature an "O-Ring" seal to protect as well as keep the valve orifice clean. Knurled head for easy on and off installation.
Brought to you by CAMISASCA AUTOMOTIVE MANUFACTURING, INC. http://www.camincusa.com/
pwdrhound
Aug 23, 2015 07:36 PM
Aug 21, 2015 06:34 AM
