Wheels/Tires
19x12s on the back. will they rub
Old Apr 4, 2011 | 10:49 AM
greekc6's Avatar
19x12s on the back with the 315's on the back? will they rub? will you have to roll the fender. also what tires are you guys running? thanks order wheels and now gotta get some tires. thanks
Old Apr 5, 2011 | 01:39 PM
tony tone's Avatar
tony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to beholdtony tone is a splendid one to behold
for starters, what car is this going on?
Old Apr 5, 2011 | 07:02 PM
greekc6's Avatar
2002 911 turbo. im ordering wheels and not sure what size to go with. the guy that im buying said 19x8.5 and asked if i wanted 19x11's or 12's. any imput help and which tire is good with either setup. thanks
Old Apr 5, 2011 | 08:23 PM
tony tone's Avatar
i sure wouldn't know as i've never owned a porsche nor do i know the offset requirements, but i've seen some wide aggressive wheels on many 911s. who are you ordering these from? I'm sure if you tell them what year/model your car is they can make the correct assessment in getting you an accurate size for your needs.
i'm sure you'll get your answer soon enough. thousands of wicked setups flow through here.
Old Apr 7, 2011 | 11:35 AM
AlexN's Avatar
AlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud of
the GT2 comes with 18x12 and a 315 tire in the back.
As long as you choose the correct offset, you should be ok.
I have a 19x11.5 rim in the back with offset of +44 and no rubbing.
as a matter of fact I could use a small spacer in there to have it real flush.
but since I'm going to switch to an 18" set soon, I'm not worried about that
Boldgt
Mar 23, 2016 11:07 AM
Oct 13, 2015 09:57 AM
V565MAN
Oct 2, 2015 05:48 AM
Sakred
Sep 30, 2015 03:51 PM
