Wheels/Tires
tpms installation
Old Apr 28, 2011 | 11:19 AM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
tpms installation
Hey guys can someone tell me, if I'm having my sensors installed on a set of wheels, do you have to balance wheels again or can they gain acces without having to dismount the hole thing.
Old Apr 28, 2011 | 08:43 PM
BretW's Avatar
BretW is infamous around these parts
The sensors are heavier than standard valve stems, so they'll need to be balanced after the install.
Old Apr 28, 2011 | 08:45 PM
solrac6262's Avatar
oh Im sorry the wheels I bought have gen 1 but I am switching those for 2nd gen sorry bad explanation..
Old Apr 29, 2011 | 09:15 AM
BretW's Avatar
The rims are wide enough, so you could possibly break the bead on the valve stem side and switch out the sensors without moving the tire on the rim. I've never dealt with Porsche TPMS sensors, so I don't know if the outer tire bead will clear the sensor with the inner bead seated. It shouldn't affect the balance, but there is that possibility and you might end up taking the car back to the shop to have them balanced.
BlueTurboS
Aug 4, 2020 08:24 PM
MadWhip
Sep 3, 2015 02:04 PM
