18" RH 3.6 Speedline Style Wheels at GMP Performance
We worked with local PCA Members to develop these fitments.
Porsche 964/965 Wide Body cars.
18x8.0 ET52 front and 18x10 ET54 rear. Recommended tire size: 225/40x18 front and 265/35x18 rear.
The P3.6 wheel and the 3.6 Speedline wheel are very similar. This package is for a 89-94 Porsche 964 OE widebody, American Roadster and Turbo. The wheel is hub centric and accepts OE lugnuts and OE center caps.
More info on this Package:
The RH 3.6 wheel mimics the classic style of the of the Speedline wheel made famous by the early 90's Porsche 3.6 liter 964/5 chassis.
The RH 3.6 wheel is a German-Made, TUV Approved, three-piece modular wheel with a cast center and spun aluminum inner and outer barrels. The center is painted in a silver metallic paint and clear-coated for a durable shine. The inner barrel is silver anodized while the outer lip is high-polished and then clear coated to protect the shine for a maintenance free finish.
The wheels accept factory mounting hardware and center caps so you can install them with your original lugnuts as well as your favorite factory center cap. The wheels are shipped with an RH logo center cap and specific, multi-piece, metal valvestem. The wheel also features a hub-centric 71.6mm centerbore to ensure a bolt-on smooth ride without the need of any additional hub-centering rings.
We have been importing the RH version of the 3.6 wheel for a number of years and our experience with the RH brand has allowed us to optimize the our fitments for a tailored look that maximizes the open area of a fender-well pushing the wheels to the edge of the fender without causing rubbing or the need to roll the fenders on a vehicle at stock ride height running our recommended tire sizes. We accomplish the fitments without the need of any spacers by combining the right inner and outer rim halves for each specific application ranging from the 930, 964, 965, 993 and 993TT.
We also have Narrow Body fitments in stock:
This is the optimal fitment on the Porsche 964. This vehicle is stock height. The front wheel is a 18x8.0 with a 52mm offset and 1.5 Inch outer lip. The rear wheel is a 18x10 with a 47mm offset with a 2.5 Inch outer lip. We recommend a 225x40x18 and 265x35x18 tire combination to fit perfectly on a 1990-1994 "Narrow-Body" 964 Porsche. Wheels weigh in at 24 pounds front, and 26 pounds rear.
Click here for details on this package
ModBargains
Aug 20, 2015 12:28 PM
