Wheels/Tires
Wheel/Rim mounting issues
Old Jul 19, 2014 | 01:40 PM
Mang0's Avatar
Mang0 is infamous around these parts
Exclamation Wheel/Rim mounting issues
Hi all,
I have a set of 22" Zenetti Roma rims I'm attempting to mount on tires. The valve stem locations are quite inadequate and (from the pictures you see below) are causing me issues. The tire shop I took it to was less than helpful and offered no resolution.
Figure 1: Mounting option area 2 (top view)
Figure 2: Mounting option area 2 - note that the tire "professional said that the TPMS sensor can not be put here because the bead seats just on the other side of the grommet and he guaranteed there would be a leak
Figure 3: Mounting option area 1 (preferred location) - side profile to show barrel to lip dimensions
Figure 4: Mounting area option 1 (top view to show how far TPMS sensor sticks out)
Figure 5: Mounting area option 1 (near horizontal view)
Figure 6: The pig! help me get some new rims and tires on here.
Right now all I can think of as a solution is perhaps some 90 degree TPMS adapters like these:
Figure 7: Credit to iForged Performance for the photo
http://www.iforged.com/store/product...45ae3d6317b015
Figure 8: Credit to accessories-pluscom Ebay user
http://www.ebay.ca/itm/4pc-ASANTI-TP...afb1af&vxp=mtr
Any help or input is appreciated. Like I said the tire shop I brought it to was less than helpful so I really have no clue what solution there is for this problem!
Old Jul 19, 2014 | 08:09 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I would try to call the rim manufacturer to see what they recommend. Normally there is a flat mounting location inside the rim for TPMS. If it does not have it, then I am curious as to how others with these rims address this issue.
Old Jul 21, 2014 | 10:14 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
Very simple all these Chinese cast style wheels designed like this. Your tpms goes on inside and rubber valve goes in front . So youll have two valves one on inside which is your tpms which will still work but you wont be able to access it to put air then you put rubber one in front which you'll use just to put air. so flip the valves as you have it in picture. simple
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Jul 21, 2014 | 02:43 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
you have 3 options, the adapter as shown and the installer has to be careful when mounting and dismounting. you mount the tire 1/2 way, put the tpms on while the tires 1/2 mounted and tighten everything down and mount the other 1/2 side. or as WB stated, drill another hole for the tpms on the drop point of the wheel and have dual valve stems. the tire shop you're going to should know what to do if they are smart.
Old Aug 18, 2014 | 04:40 PM
Mang0's Avatar
Hey all thanks for the feedback,
What I ended up doing was yelling at the vendor then sending a large well-worded complaint letter to the wheel manufacturer.
In response they sent me machined hub-centric 15mm spacers, and the 90 degree valve stems I require as well and a t-shirt.
I respect a company that is willing to rectify an issue, especially when the vendor was less than helpful
Jul 29, 2019 11:13 AM
alwaysbored786
Apr 19, 2016 05:51 AM
RallyBird
Oct 7, 2015 01:20 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
