Wheels/Tires
do offsets affect alignment?
Old Feb 25, 2015 | 09:22 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Do using a different offset wheel affect alignment if all else is equal?
Goggle search provides different views but the knowledge is among us.
So is using a set of winter wheels and summer wheels with different offsets
a good idea?
Old Mar 4, 2015 | 02:54 PM
damon@tirerack's Avatar
Moderator
If your widths and offsets are close enough that both wheel sets fit without rubbing, than you will probably be OK by not getting an alignment between switches. Flat is flat. Going from a wider tire to a skinnier snow tire has less effect on alignment as long as that alignment is a good one.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Boldgt
Mar 23, 2016 11:07 AM
miken168
Oct 6, 2015 09:21 AM
Sakred
Sep 30, 2015 03:51 PM
SaviniWheels
Wheels/Tires
Sep 29, 2015 07:04 PM
