Help - Nore more Power windows, burn light on dash and Two Beep Alarm
Hi,
I have this very strange issue, so here are the symptoms.
1- No more alarm led on dash
2- Windows will not go up or down both side under any circumstance
3- Two horn when arming
4- Windows will go down when opening doors
5- All the buttons on the right portion of the horseshoe that surround the radio does not lit at night.
6- Doors will not lock or unlock
Anyone know whats wrong...
Car is 996 TT 04
Bo
Car is 996 TT 04
Bo
to numerous and disparate issues for it to be the ignition switch I'm going with wire harness or your ECU is bugging in some related way
Ignition switch on my car caused some weird fan under the dash to run, wipers to run whe it detected rain, and who knows what else when the key was out. The switches GO on these cars and don't buy the knock off switch either! If it's never been replaced consider it. If the key is stiff to take out of the ignition swap it NOW!
04-28-2022 12:38 AM
