My experience with GT2RS intercoolers
So i did a full 4th gear pull....
I got stock intake, billets, 630injectors and exhaust.
Pull starts at 2994Rpm, intake temps at 24degrees celsius (75F)
And ended at 7351rpm and the intake temp was at 50! degrees celsius (122F)
This was measured with durametric.
Is this normal figures with these intercoolers?
I was hoping they performed a bit better..
Instead of saying they're no good without providing any comparative data whatsoever, why don't we actually ask about OP's setup to see if there's another issue going on here?
Ronny, how much boost are you running? Did you do a boost leak check on the car after putting it back together?
Can you post the actual log?
The temps seem on the high side for a single 4th gear pull. I would expect 15-20C over ambient in a single 4th gear pull at ~1.3 bar of boost and those ambient temps. You shouldn't be seeing much over 40C in those conditions unless you're in 1.5 bar + territory.
As a quick check, temps shouldn't budge much at all in 3rd gear (try that with a Bell or Treadstone core...). As 32krazy said, it's good, but not as good as I would expect (unless you're running a good bit of boost)
Thanks guys, i have posted the logs here:
https://www.dropbox.com/s/pafspw83nj...hgear.xls?dl=0
Skip to line 1450 for the pull.
I had a small leak in the venturi tube, i have replaced that now, but havent been able to do any new pulls.
Im running a markski tune and we are not 100% done with the setup, pending the results after the venturi tube change and check of the actuators.
So i need to figure out if these temps are normal, or i have a issue i should sort.
For instance i have billets from a norwegian company, and the gt2 wing with its forced induction (through the pillars to the wing), also standard airbox and intake.
So maybe these are factors as weell that causes the high temps.
Any suggestions are welcome.
Air through the gt2 wing, assuming it's sealed well, will draw cool air. Can't speak to the intercoolers but tune will effect IAT.
I have old skool k24 hybrids, my passenger side intercooler is instrumented with a gauge. I see drops of 90+ degrees pulling through 4th on SRM coolers. Outlet temps are above ambient but I don't recall how high and my measurement wasn't IAT but exit temps. I fully expect to be posting a huge amount of data on these as soon as I get my car back. I'll be beyond shocked if the GT2RS can keep up...
On a 70 degree day with back to back pulls, I will see roughly 20F degree temp increases through my SRM intercoolers. I'm still on stock K16's and could argue they're gonna generate a lot more heat than billets.
I entertained the idea of GT2RS intercoolers in the beginning but after reading a decent amount of bad press, this included now, I'm happy I went with SRM.
I wasn't running tons of boost previously, I'll be running a good bit now but it will be ramped. I can easily turn it down for testing. I have no way to record the readings from my differential gauge but come Winter when I'm comfortable with my engine management I may pull the driver's side intercooler for instrumentation. Until then I will be able to get numbers on IAT, boost, egt, backpressure, and mph here soon. I can do a visual on the differential gauge to see how much I'm dropping or what intake or outlet temps look like.
I have a sneaking suspicion we pick up a decent amount of heat from intercooler exit to IAT but it's just a gut feel that I hope to validate. I'll now have a fabricated Y-pipe, billet plenum, and larger throttlebody. I'll be drawing air from alongside the intercooler ducting which remains sealed so intake restriction SHOULD be far less - I may instrument this to check for restriction. If I see temps climb much from IC exit to IAT I'll be insulating to try and reduce it! Lava wrap and gold foil?
Honestly my biggest issue is likely going to be finding room to test! My setup may be too much apples to oranges for others but my intent is to test and share, we need more data! I look forward to Pwdr getting his car on the track with the uber cores and good data acquisition too as I expect his will work even better at some $ cost. I still want to see data from side scoops too and might be willing to try them.
Here's a log with SRM's.
As stated earlier, I can imagine stock K16's will generate a crap ton more heat than any of the upgrades, especially at 1.2bar.
This is run number 2 of back-to-back runs. I should also note that I have an open "fabspeed style" airbox.
I need a log with a fourth gear pull to compare.
Id really like to see some one elses 4th gear pull with gt2rs ICs, as i need to know if this is how hot they get, or if there is something wrong with my setup
All you have to do is search the forums here: you'll find plenty of info that shows that, aside from very high $ IC cores like powdrhnd is working with (in conjunction with SRM) in his "Ultimate Intercooler" thread, the only ICs that work worth a poop for longer runs - such as a road race - are the GT2 RS ICs. On a short acceleration run, a big, heavy IC acts as a heat sink and will keep the intake charge cooler longer than the GT2RS ICs. But big, heavy ICs will remain hot throughout following braking/acceleration cycles if they follow quickly - such as in a road race. And, where people are drilling aluminum parts to save weight, they are generally very heavy.
But for the 1/4 mile, big, heavy aftermarket ICs are likely better.
Search earl's posts. He has done more than any other person or company here on the forums regarding comparative research on intercoolers.
And I have no idea what sort of cores SRM is using in their 4.5" ICs. All I know is that Blkmgk has a set and is hoping that they are really good
