Where to get a replacment wheel lock key
Took my car to America tires today and they somehow messed up the key to my wheel locks. I have the key still but the insides are all messed up... Any other place to get other the dealer?
The dealers should have a master set of keys. Without a key, if they stripped the key you'll have to find another way to remove the bolt then replace with a new set of lockers...but I wouldn't spend money for the lockers - you'll see that when you see how easy it is to remove the bolt without a key.
Yeah they stripped the key but the bolts are all fine. Funny thing is I also have a set of bolts and another key sealed in the trunk. Key doesn't match but found it kind of odd that there's another set in there.
Wow! My key has a few numbers stamped on it so figured they can find it with those digits.
Dealer is the only place, unless you could order it off the number from Suncoast or something.
As another suggested...put a regular lug bolt....thieves can do just what you are doing
Good luck..
DC
3WDistributing
31
10-27-2017 01:26 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
