Wheel question
I'm looking at a set of wheels and tires and wanted opinions on if the would fit and how the would look.
Rear 20x11 et 45 295 35
Front 20x9.5 et 35 255 40
Lug pattern 5 x114.3
IN this thread you have all the tools you need to literally look at it on screen. But from the many many threads I have seen, the best appears to be offsets of 42 and 52 with 9 up front and 11 rear for the Vantage. Tire size is either what you have, or 245.35.20 up front and 305.30.20 or 295.30.20 rear
https://www.6speedonline.com/forums/...ory-guide.html
Just a thought Gene, you had DBS first gen wheels on your last, what about second gen ones? Just a thought. I am likely going with the BC Forged RZ21's.
I thought vehicles get speed info from the gearbox? or on some of my toys this is the case,or am I wrong?
Greg-----whats the change with the Avatar???? Putting the RR outside now?
Depends on the car. Some get it from the transmission, but these get it from wheel speed sensors.
I was looking at some aftermarket wheels and noticed that a few had setup 19" in front and 20" in the rear and even 20" front and 21" rear... I was wondering if anyone tried that on their Aston Martin before and if so is it the front or the rear that the speedo uses for accuracy. Don't think it would be a good setup for track use but for regular driving??? Thanks
