1993.5 Toyota Supra, 6SPD, low miles, tastefully modified!
Year: 1993
Make: Toyota
Model: Supra
Price: $37800
Mileage: 80740
Color: Black
Location (State): AZ
Transmission: Manual
Drivetrain: Rear Wheel Drive
I have a book of receipts and manuals from years ago to date. I also have original boxes for a lot of the parts. Boost gauge, Double din, etc..
I have no lien on the car and clean/clear title in hand.
Supra now only has 80,700 Miles. This is not my daily but this is my relaxation therapy sometimes so the miles may go up a little as time goes on.
Motor:
Boost Logic single turbo conversion
Boost Logic Ceramic Heat Coated Tig Welded Tubular Header
Garrett T67 ball bearing turbo with .68 exhaust housing for fast spool
HKS 50mm wastegate
HKS type R 3 row intercooler
Tial 50mm blowoff valve
Fluidamper crank dampener
Boost Logic timing belt tensioner bracket
egr block off plates
3 in turbo back exhaust with Blitz muffler
RPS Clutch
Fuel:
Boost Logic Fuel Rail
Dual Walbro 255 LPH Pumps
Aeroquip AN fittings and Braided lines
Aeromotive -10AN Fuel Filter
Aeromotive -10AN Fuel Pressure Regulator
0-100PSI Fuel Pressure Gauge
6 Injector Pig-tails
High Quality Relays and Power Lines
850cc Precision injectors
AN Lines all the way to gas tank
Electronics:
AEM gen 1 standalone engine management - Tuned by UMS Tuning 2 months ago - Tony tuned the Supra both on Dyno and Street. Idles great and even drives better! 487 WHP and 442 Tq on 91 octane.
AEM UEGO wideband - Hidden in middle console for clean look
MOJO LQ9 Coilpack upgrade
Innovate SCG-1 boost gauge - Can also control boost or read Air fuel
Blitz Turbo timer
TRD 10,000 RPM Tachometer
Pioneer double din AVHX4700BS - Has USB, Ipod connection, A2DP, and Phone mirroring via USB
98 Tail lights
Painted Headlight with HID - Looks very similar to 97-98 headlights
Wheels:
Volk SF Challenge / Gunmetal color
19x9.5 Front 245/35/19
19x10.5 Rear 265/35/19
Suspension:
Tein Super Street Coilovers - Adjustable height and dampening
Misc:
- Front lip
- 98 Toyota Supra 3 spoke steering wheel with airbag
- Reupholstered interior from Beige carpet and Seats to Red seats and black carpet. The seats were also re-padded so they look and feel like the day they came from Toyota
- Rear Seat Delete - Upholstered red to match the seats.
The Supra comes with a bunch of parts:
- Brand new braided brake lines - Never had a chance to install them
- Double gauge pillar
- OEM front lip - In excellent shape
- removed charcoal canister
- No traction control due to AEM ECU
- TRD oil cap
- Carbon fiber radiator panel
- Polished upper rad hose
The timing belt, tensioner, water pump, serpentine belt tensioner and shock all were replaced and have about 6,000 miles on them.
The bad:
- The rear bumper could use a respray due to two spots showing a spider effect. Hardly noticeable from a few feet away. (Picture included)
- Little warning light comes on when the lights are turned on due to the 98 tail lights. Easily fixable by switching out the relay in the trunk with a higher voltage relay - I don't do electrical so I didn't touch it. I do have the DIY URL
- 1 small ding on passenger side behind passenger door (Picture included)
Besides the few items I mentioned above, The Supra needs nothing!! For a car this old, to me that's amazing!! Everything works as it should and AC blows ice cold! I don't daily my Supra but even being in traffic in a HOT 110 degree AZ weather with the AC on, the temperature gauge will not even reach the half point.
If you have any questions PM me and I will get back to you right away!
I removed the pictures with beige interior so I don't confuse anyone. The interior was upholstered less than a month ago.
Care to share some information with my about your build? Keeping the Supra and building a monster is always on my mind
I was told switching to E85 with my current setup by only switching out the Fuel pumps and injectors I can make 700 whp+
This is an awesome car. I was having fun just reading through the entire post. I usually never read an entire ad post... Maybe I'll skim through it.
I wish you the best of luck. This shouldn't last long.
