07 Porsche cayman steering wheel removal /any DIY step by step out there?
Old Sep 7, 2010 | 09:27 AM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
does anyone have a step by step on how to remove the steering wheel on a 07 Cayman ?
Old Sep 7, 2010 | 11:20 AM
Atob's Avatar
Atob is infamous around these parts
i found this... pretty helpful.
File Type: pdf
Old Sep 8, 2010 | 01:23 PM
Fluid987's Avatar
Atob
i cant seem to open the atachment?
also anyone know how to remove the stock HUB? Thanks
Old Sep 8, 2010 | 06:29 PM
dave4tide's Avatar
dave4tide is infamous around these parts
unhook the battery
get a screw driver, key turn the blade vertical and push it into the hole on the underside lower section of the steering wheel. It should pop the air bag free.
pull the little clips on the back of the plastic fasteners.
remove the steering wheel with a 12 mm 12 pt socket
article link
Old Sep 8, 2010 | 08:04 PM
Atob's Avatar
it's a PDF... when you download it, is it getting renamed? an new suffix?
if so, just delete the suffix and add '.pdf'
Old Sep 9, 2010 | 04:57 AM
dave4tide's Avatar
I couldn't open or save the .pdf to my desktop.
Old Sep 10, 2010 | 06:19 PM
00spyder's Avatar
00spyder is infamous around these parts
There used to be some instructions posted on Planet-9 (former Cayman Club). Might want to check and see if they are still there.
Old Sep 10, 2010 | 06:56 PM
Fluid987's Avatar
00spyder
Ok got it ,found it and have removed the stock wheel !! thanks
COBB Tuning
Jan 1, 2025 09:02 AM
no1joey
Sep 2, 2015 12:32 AM
Aug 20, 2015 12:17 PM
pwdrhound
Aug 20, 2015 05:54 AM
Jakk55
Aug 20, 2015 05:47 AM
