DIY spark plug change for '05 CTT?
Old 12-03-2008, 01:52 PM
cayenne-kimo's Avatar
cayenne-kimo is on a distinguished road
Anyone have a link or how-to- change spark plugs on an '05 CTT? Shops are quoting $350 to change these which includes two hour labor. I tried searching on here but no reference to anyone changing their own spark plugs.
Thanks.
Old 12-04-2008, 04:31 AM
Anybody?
Old 12-04-2008, 06:33 AM
B Feelgood's Avatar
B Feelgood is on a distinguished road
I changed the plugs and coil packs this weekend on my 2005 Turbo. It is definitely a DIY job. The hardest part is removing and putting on the passenger side engine cover.
1. Remove all 5 black plastic pieces that surround the engine bay area.
2. Remove engine brace on passenger side that's bolted to engine and lift out of way "big screw."
3. Remove 4 torx bolts that hold the receptacle piece for the engine brace and move out of way.
4. Remove the three silver engine covers that cover the coils/plugs.
5. Unscrew torx screw that holds the coil pack in place and pull out.
6. Remove spark plug with extension.
7. Put in new spark plug.
8. Put in new coil.
I strongly suggest replacing the coil packs as well as they are known to crack over time. They are cheap enough to do as preventative maintenance.
Hope this helps!
Old 12-04-2008, 06:40 AM
tonga3's Avatar
tonga3 is on a distinguished road
I did the coil packs 2 weeks ago on a CS, it is deinately a DIY job.
Old 12-04-2008, 08:25 AM
8. Put in new coil.
Hope this helps!
Thanks! That's what I wanted to hear. About how long for the whole project? Do you have the torque specs?
Old 12-04-2008, 05:09 PM
tonga3's Avatar
I'll post the torque specs when I get to work tomorrow.
Old 12-05-2008, 05:30 AM
tonga3's Avatar
Here they are.
Tightening torques
Location Thread Tightening torque [Nm] (ftlb.)
Spark plugs M14 x 1.25 30 (22)
Initial tightening 25 (19)
Ignition coil M6 10 (7.5)
Fastening screws of design cover M5 5 (3.5)
Bracket for torque arm M8 x 45 23 (17)
M6 x 40 5 (3.5), then 10 (7.5)
Torque arm on bracket M10 x 70 60 (44)
Torque arm on body M10 x 20 60 (44)
Secondary air pump M6 x 50 10 (7.5)
Old 12-05-2008, 03:38 PM
Thanks Tonga3!
Old 12-05-2008, 05:26 PM
tonga3's Avatar
Happy to help.
Old 10-19-2009, 01:25 PM
stmcleod's Avatar
stmcleod is on a distinguished road
04 CTT spark plugs
is there a difference between the CTT and the CS?
i have an " air pump at the back that seems to be in the way on the left side.
does this need to be removed?
Old 10-20-2009, 02:10 AM
eVoMotion's Avatar
eVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant futureeVoMotion has a brilliant future
thanks B feedgood!
Old 10-21-2009, 02:30 AM
1dirtyz's Avatar
1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice1dirtyz is just really nice
what plugs do you guys recomend using ?
Old 02-17-2010, 06:38 PM
jmrz2k's Avatar
jmrz2k is on a distinguished road
Hi,
are those 12 point torx or 6?
Thanks in advance!!
Old 08-09-2013, 06:47 AM
Mlee2623's Avatar
Mlee2623 is on a distinguished road
What brand did you use? Where to order. Thanks
Old 08-09-2013, 09:06 AM
ECS Tuning - Porsche's Avatar
Not sure on your model Cayenne, but we offer a array of coils and plugs to choose from. For more information Click Here. Let me know if you have any questions.
Quick Reply: DIY spark plug change for '05 CTT?
