Interior fan squeaks when turning left...help
Old 01-29-2012, 09:54 PM
thor7000's Avatar
thor7000 will become famous soon enough
As the title says, the interior fan just began to squeak...usually starts when you make a left hand turn!! Sounds like a bearing is dry or something...has anyone else had this problem?? If so, is replacing the blower a possible DYI, and what do the blowers usually cost??
Thanks,
Old 01-30-2012, 05:45 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
YES!!! I have this problem too!! Very weird.
Old 01-30-2012, 08:31 PM
crowland's Avatar
crowland will become famous soon enough
Yes i had the same problem rhis summer-Mine sounded like a little bird was chirping in my passenger glove compartment. It was kind of hard to explain to the dealer and isolate what it was exactly because like you mention it was only during right hand turns in my case, but the dealer ended up putting a new blower in. For a time i thought it was something qith the suspension. However over the span of about a month and running the A/C on end with the 100 degree summer in texas it finally crapped out. Sorry I don't know of cost as mine was replaced under CPO. There is quite a bit of room to work in that passenger footwell so I wouldn't think it's too hard of a DIY-
Old 02-01-2012, 05:05 AM
thor7000's Avatar
Well....my engine light came on so I took it to the dealer yesterday, turns out my coils crapped out so got them replaced under the coil extended warranty!! While there I had the dealer replace the fan for me, it cost $411 but comes with a 2 year warranty on the blower and seeing how the lowest price I could find just for the blower was $201.00 figured I get it done!!
Old 02-27-2015, 12:59 PM
Saggio's Avatar
Saggio is on a distinguished road
Revive an old thread...
My interior fan sounds like a bird chirping. Dealer wants $350 for the part! Eeeek
Old 02-27-2015, 01:10 PM
crowland's Avatar
This blower motor assembly should be interchangeable with the VW toureag part - which is a few bucks cheaper. This is a well documented DIY. The part can be located for less than $150. I found one for my '08 for around $100, but believe it was aftermarket and not OEM.
Old 02-28-2015, 07:27 AM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
FWIW, I found the speed resolution in the lower range wasn't as good on my non OEM replacement. It actually ended up mattering because the first three bars for fan speed is where mine spends most of its time.
Old 03-03-2015, 09:28 AM
Saggio's Avatar
Found OEM for $288 Aftermarket for $150.
Thinking about using my warranty for it, maybe they can find something else wrong that would make it worth taking it in.
Old 03-15-2015, 04:36 AM
Jagman1's Avatar
Jagman1 is on a distinguished road
I had this issue in an Volvo V70 that I used to have. I removed the blower fan, then lubricated the shaft where it enters the motor. That eliminated the squeak for the subsequent four years I owned the car. To get the oil into the shaft, I had to drill a small hole into the plastic hub of the fan in order to drip the oil into the right spot. Worked like a charm, cost a total of 1 hour.
Old 03-16-2015, 07:43 AM
Saggio's Avatar
Jagman thats awesome that you made that work! I did take mine out a lubed the area that was making noise. Put it all back together and turned the fan on and it is now louder! lol
Old 03-21-2015, 04:42 AM
Jagman1's Avatar
Sorry it didn't work out. Worth a try in my opinion.
Old 03-24-2015, 09:57 AM
Saggio's Avatar
Going in tomorrow and having the dealer replace under warranty.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
turbotuner20v
09-11-2015 12:02 PM
LiquidElephant
08-27-2015 06:17 PM
Quick Reply: Interior fan squeaks when turning left...help
