CTTS '06 not making power?
Hey guys, The CTTS has been sluggish and after scanning with a durametric I found no relevant codes. Since I have 77k on the clock, I went ahead and changed plugs and coils (sourced from Suncoast). Although it runs a little smoother, power is still way down. I'm thinking possible boost leak?
I logged some data for nominal boost and was hoping to see if anyone may have some insight? The data was logged during a 3rd gear pull from 2k RPM to about 7k RPM. Thanks for the help...I'm really hoping it's not a bad turbo, or turbos
Listed mods:
Eurocharged Tune
3" Lesitung Cat bypass pipes
3" Leistung full exhaust
Leistung intakes
Forge diverter valves
I ran the pig with a Gtech pro (slightly downhill) and my 1/4 mile was...14.6s!!!!!
Listed mods:
Eurocharged Tune
Leistung intakes
Mr. Haney, Are you recommending the compression and leakdown test base on my data log? I was thinking this may be more boost related...I really hope it isn't anything internal
I don't have a durametric and I have no idea what the data log said lol, I know the CTT "CAN" throw a code for overboost or underboost conditions. If your not getting any codes you gotta start with the basics. How many miles do you have? How do you drive, honestly? Im learning a lot about the CTT while I'm building a motor and replacing my two turbos.
I'm not really sure how to read that because it doesn't look like it's showing rpm's but if im reading the boost correct it says your running 2.05 bar and if so that's a lot, like 29.7psi a lot. the stock 06 CTTS only runs 1.9 bar which is 27.5 psi. So in theory it should be running strong but without a baseline of how it ran before boost wise it's hard to say.
Sounds like you need to drop it off at the dealership and let the professionals take a look. I certainly wouldn't be driving around in something that isn't performing like it's supposed to. Something has obviously changed and it would be horrible to find out that is was a simple fix until driven around while a minor problem was developing into a major one.
Vig03,
Why are you only logging two variables? I checked out that log sheet you attached and verified that you are maxing out at about 1.1 bar with those mods, which is about right. Other than that, I cannot tell anything else.
Here is an example of a Durametric log that I took a while ago. I would log these same variables and also include the MAF values.
Also, do you have any other symptoms, like backfiring?
Vig03,
I just happened to take a second look at your log file. Why are almost all the entries for RPM, 1380? And nothing is past 1500 RPMS? Are you having issues capturing information with your particular laptop? Something is amiss here...
Cuemaster, I hope it's that easy! The DVs are Forge and have less than 4k miles on them. I have seen a few posts of new valves leaking, so it's definitely worth checking out.
I easily log about 4 entries per second with about 15 variables selected. If you look at my log, it correctly logs the RPMS. I think it is time for a new laptop. Try to use another machine and take another set of logs.
Ok that's good to know. The laptop is pretty new so I'd be surprised if that's the issue. I did notice that on your log you used engine speed and I used "Idle speed specified RPM". Maybe I just used the wrong parameter. I'll try to log again tomorrow with the parameters that you used and post the results... Thanks!
It will automatically select these 15 variables.
