957, What to know before buying
My wife and I are considering buying a 957.
What do we need to know?
It is going to be a daily driver.
Open to the V6, no need for big horsepower.
Coolant issues?
We own a 996.2 now, so we aware of possible issues in m96.
thanks
Coolant issues?
thanks
Coolant pipes are only a problem for the 955. 957 most of the 955 problems where fixed, I've had two 955's bought both new, the V6 was great, but the V8 makes this truck move. not underpowered at all, a bit nose heavy though. I'd go for the V8, and Plus the way the S looks on the back.... Have to say that was one of the reasons I got rid of the V6 I wanted an S on the back
still not sure of all the differences between base and S, other than V8
The v6 doesn't have the coolant pipe issue.
It does suffer from the Cardan shaft issue and gearbox (transmission) valve body issue which is common to all 955/957 regardless of engine.
The hatch struts also fail which means the lid wont stay open, again this is common to all 955/957.
I used to have a 957 v6 base and it had enough power. I had no issues with the engine, just a hard downshift from 4th to 3rd which was the gearbox valve body. It got better after I had the gearbox oil and filter changed.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
The captain obvious between the base and S, S has larger brake rotors, typically different size wheels and there are exceptions to that one, more HP and more torque if you plan on towing and flat out more acceleration. The S is typically 5k more in the used market. The S is worth it if you want shorter stopping distances, more torque for towing and improved acceleration, lastly the V8 sound. Although I have heard some V6's with aftermarket exhaust that sound really good.
Now the question was what to look for, I have replaced the following since I bought my S used with 99k on the clock, now have 115k
Cardan shaft
Rotors and Pads but that's normal wear and tear
Starter
Turn signal switch- my fault
Cardan shaft
Starter
