Headlight
Headlight
My 996 turbo has one headlight that is hazed. The other one looks perfect. (weird huh?)
What is the best way to remove the yellowing and restore its optical clarity? I don't have a power buffer so please do not recommend product that require it.
Thanks.
Thanks.
You will want to wetsand the entire headlight with 2000 grit, then polish. You can buy an attachment for a powerdrill that holds a mini 2 inch or so buffing pad. You will need a machine to polish it out, but should look great when done.
John
John
I don't think you'll be able to do this task without a polisher. You need the heat and friction of a polisher to break down the oxidized layer on the headlight.
DYL 911
04-19-2016 11:29 PM
ECS Tuning - BMW
09-29-2015 01:18 PM
