Spacers for 2014 Panamera 4S?
Old 09-01-2014, 04:06 PM
bmellion's Avatar
bmellion is on a distinguished road
Hi everyone!
What are the ideal spacers front/rear for my 2014 Panamera 4S with 20" OEM wheels. The rear isn't that bad, but the front really needs help!
Your help is greatly appreciated! Where to purchase would also help. No rubbing please! 😜
Old 09-02-2014, 02:26 AM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
Which 20" wheels to be exact?
Old 09-02-2014, 05:18 AM
bmellion's Avatar
These...
Old 09-02-2014, 06:20 AM
echristie's Avatar
echristie is on a distinguished road
I would be interested in the information as well.
Old 09-02-2014, 07:11 AM
cvprez's Avatar
cvprez will become famous soon enough
I was running 5mm spacers on my 2010 PTT both front & rear - my 2013 PTTS came with the rear 5mm spacers standard so I have an extra set of 5mm ones available if that's what you decide you want. You could probably push it to 7-10mm if you really want them flush but the 5mm on both axles do make a visibke difference.
Old 09-02-2014, 07:28 AM
EliahP's Avatar
EliahP is on a distinguished road
Originally Posted by bmellion
These...
Your Panny is beautiful!!
Old 09-02-2014, 07:36 AM
bmellion's Avatar
Thanks for your response. Did you have to use extended bolts for the 5mm spacers? From what I understand, you can use the standard bolts??
Old 09-02-2014, 07:37 AM
bmellion's Avatar
Thank you! I love it!!
Old 09-02-2014, 10:46 AM
cvprez's Avatar
the lugs on the 2013 are the same length front & rear (rear came with factory spacers) so either they are all longer or none are longer (if that makes sense)
Old 09-02-2014, 06:46 PM
tonyep's Avatar
These...
15mm front, 5mm rear on that wheels.
Old 09-07-2014, 06:45 PM
bmellion's Avatar
Went to my Porsche Dealer and was told that my 20" Sport Black wheels are a no-no for spacers. Makes no sense to me. It's a god damn spacer. Need to go aftermarket I guess
Old 09-07-2014, 10:30 PM
tonyep's Avatar
Dealer will definitely follow what Porsche says. They do not want any liability.
I am currently running 15mm front and rear RSS spacers on the Turbo II wheels, no problem at all. The 20" Sport wheel can only take 5mm spacer at the rear cause it's 1/2" wider and 5mm lower offset to begin with.
Old 09-08-2014, 08:27 AM
bmellion's Avatar
Dealer will definitely follow what Porsche says. They do not want any liability. I am currently running 15mm front and rear RSS spacers on the Turbo II wheels, no problem at all. The 20" Sport wheel can only take 5mm spacer at the rear cause it's 1/2" wider and 5mm lower offset to begin with.
I was thinking 5mm rear and 10-15mm front. Thoughts?
Old 09-08-2014, 04:57 PM
tonyep's Avatar
How flush do you want the front to be? Going with 10mm will make it the same as your current rear. If you're going to be putting 5mm at the rear then i'll suggest 15mm at the front.
Old 09-08-2014, 05:19 PM
bmellion's Avatar
Got it! Thanks! Does anyone make wheel locks on the extended bolts?
Quick Reply: Spacers for 2014 Panamera 4S?
