iPD Plenum VS Agency Power Carbon Y-Pipe
Old 04-01-2016, 08:35 PM
MIA997TTBeast's Avatar
MIA997TTBeast will become famous soon enoughMIA997TTBeast will become famous soon enough
Originally Posted by Nick_GT
I wrote that it's dropped to 7.6sec after installing HJS sport cats 200cell because the result is worse(!) than with SS downpipes (which is 7.3sec).
Different words - with downpipes car goes faster for 0.3sec on 100-200km/h.
However, i like the mid. rpm range more on HJS cats. I assume that backpressure playing important role in it give the feel that car goes smoothly (less turbo lag?).
Which HJS downpipes did you have before? Fabspeed? I know they use HJS.
According to you SS with 200 cell yielded better results than your 200 cell HJS downpipes setup you had before.
I'm asking as I didn't know that a 200 cell cat from different vendors would make a difference. If it does is always good to know.
Old 04-04-2016, 05:03 AM
spi750kz's Avatar
spi750kz will become famous soon enough
Originally Posted by XLR82XS
SS downpipes? Downpipes either with or without CATS. You're saying cat-less you gained .3 sec.... Turbo cars dont need the back-pressure and as such a cat-less setup on any boosted application will remove restriction and always yield gains.
Hi,
http://www.supersprint.com/ does in a different way
downpipes are cat-less after them you may choose 3 options 200 cats, straight pipes, etc
http://www.supersprint.com/ww-en/por...-hp-2010-.aspx
I like them better then others because they are made from 70mm pipe versus 60mm offered by other companies
Kind regards
Old 04-04-2016, 02:05 PM
Nick_GT's Avatar
Nick_GT will become famous soon enough
100-200km/h:
SS* downpipes + SS straight pipes + SS X-Pipe + PSE Mufflers = 7.3sec
SS downpipes + SS 200 Cell cats (HJS) + SS X-Pipe + PSE Mufflers = 7.6sec
*SS - Supersprint
Old 04-05-2016, 11:44 AM
100-200km/h:
*SS - Supersprint
Understood and it makes complete sense. No/lesser restriction means more power.
Now that smell is a different story.
Old 03-11-2017, 10:30 AM
makoto's Avatar
makoto is on a distinguished road
Does this Y pipe fit the 970 turbo S?
I bought this part long time ago, I've tried to install it recently, at the beginning the stock vacuum tube is not long enough so I bought a vacuum tube, then we found that the stock inlet manifold is too big, we can't get this Y pipe in, so we took off everything in the front, Bumper, intercooler, water tank etc everything! Finally we got it in and then we found the inlet manifold is still too large, there's no space between the manifold and the Y pipe, and the Because of this the Y pipe can't be attached back to the turbo hose....we finally gave up....put everything back on again,
Did anyone install this Y pipe on a Panamera Turbo S before? Does it fit?
drinaldis
09-28-2015 01:37 PM
PenguiN
09-15-2015 11:44 AM
Superaudiofreak
09-04-2015 03:22 PM
km90265
08-31-2015 11:00 AM
Ferrari
08-24-2015 04:35 PM
Quick Reply: iPD Plenum VS Agency Power Carbon Y-Pipe
