Procharged Pro Touring 68 Camaro for sale
Due to some unforeseen circumstances, a deterioration in my current business, and a new opportunity I am working on, I am putting my 68 Camaro up for sale. It is currently about 80-85% complete and being worked on daily at Gearhead Garage in Sacramento, CA. This is the same shop that built Mike Bassi's awesome 67 Camaro that was a Lateral-G Feature of the Month.
http://www.lateral-g.net/forums/showthread.php4?t=6143
I have tons of pics on threads and in my photo album here:
http://picasaweb.google.com/dwgordon/68Camaro
http://www.lateral-g.net/forums/show...light=gearhead
http://www.lateral-g.net/forums/show...hlight=vertigo
Here is a parts list that is up to date and either in hand waiting to be installed or is already installed:
All new sheetmetal
BMW Sterling Gray paint
smoothed firewall
custom dash insert with 7 Auto Meter gauges (not finalized)
406 cubic inch small block (dyno'ed 700 rwhp) built by Jody Bernard
Factory 400 2-bolt block with partial fill
Eagle 4340 steel 3.75" crank
Eagle 4340 steel 6" H-beam rods
Ross custom blower pistons
Speed Pro Plasma rings
Milodon 7 quart pan
Cloyes true roller chain
Comp Cams hydraulic roller blower cam and lifters
AFR rev kit
Victor Jr. heads with Stage IV port by CFM Performance
Crower stainless 1.6 roller rockers
Holley Stealth Ram intake manifold and throttle body
RC Engineering 75# injectors
MSD 85551 billet distributor with GM melonized gear
MSD 8mm wires
D1SC ProCharger with 11 and 14 psi pulleys
ProCharger brackets, pulleys for water pump and power steering pump
Power Steering pump
McLeod aluminum 168 tooth flywheel with steel insert
Edelbrock Victor aluminum water pump
GM Performance cast aluminum valve covers
FAST EFI and harness
Keisler Engineering TKO 600 5-speed transmission
3" 1053 steel driveshaft with 1350 yokes
McLeod RST clutch rated to 800hp
Currie Ford 9" rear with 3.70 gears
Wilwood disc brakes front & rear –
13" rotors/6 piston fronts
12" rotors/4 piston rears
Hotchkis front sway bar
Unisteer rack and pinion steering
Flaming River stainless steel tilt steering column
Flaming River Waterfall steering wheel
QA1 adjustable coilover shocks
Air Ride Technologies Air Bar 4 link rear suspension
Hotchkis Subframe Connectors
Mini-tubbed
Air Ride Technologies Strong Arm upper/lower control arms
Hydraboost brake booster
Custom-made stainless steel 1-3/4" to 1-7/8" stepped headers with Cape's
high temp coating
Spintech Sportsman XL mufflers
Modo Innovations pedal kit
Modo Innovations electric trunk release
Treadstone Intercooler 1500cfm
Cyclone Rods radiator with dual Spal fans
Mach 1 gas cap
custom built Esajian Wheels forged alloy 2 piece wheels
powdercoated gloss black centers, polished hoops and lips
18x9.5 front with 6.25" backspacing
18x12 rear with 6" backspacing
Nitto 555 tires front - 275/35/18
Nitto 555R tires rear - 335/30/18
ISS bucket seats
custom leather upholstery and microsuede inserts front and rear
ACC cutpile carpet kit with floor mats
Marquez Design 1969 RS tail lights
Twist Machine fender braces
Twist Machine shifter
Kwik Wire harness
Rick’s stainless steel fuel tank
in-tank Bosch fuel pump
Billet Specialties battery mount
I know we're in a tough market, but I am looking for $55k as it sits now. As most of you know, this is less than the cost of the parts and the car before adding in labor.
This is a moving price as parts and labor costs are being incurred weekly. There is roughly $15-20k left to finish the car the way I planned on doing it, but it could be done for $10-12k if need be and still be fantastic. A buyer now gets to decide on all of the final fitment, design, and trim decisions. Otherwise, I finish it and sell it completed in 2-3 months.
I am located in San Francisco and car is in Sacramento.
Please email dwgordon at gmail dot com with questions, offers, or to get my phone number.
Thanks for looking.
All new sheetmetal
smoothed firewall
Milodon 7 quart pan
AFR rev kit
MSD 8mm wires
Power Steering pump
Mini-tubbed
high temp coating
Mach 1 gas cap
ISS bucket seats
Kwik Wire harness
Thanks for looking.
This motor has under 1000 miles on it and was in a nearly identical 69 Camaro before I bought it. It did not have an intercooler (water injection only) and made just over 700 rwhp with 14 lbs of boost on a Dynapack.
My biggest mistake (not really) was getting into the 996TT while waiting for this car to be finished!
Most parts are there, at least the major stuff. The only major parts left to be purchased are things like intercooler tubing, 3" exhaust tubing (already have Spintech mufflers), the grille, and a bunch of misc stuff.
So yes it is mostly labor left. The car should be done in 30-45 days.
You interested?
You interested?
turbotuner20v
09-11-2015 12:02 PM
I'mAllIn
09-11-2015 06:38 AM
