Any tips on bleeding the clutch?
Old 02-20-2017, 09:34 PM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
GT2 master/slave conversion. Clutchmaster Stage 2 disc. Everything working fine before I started the project
I was bleeding my clutch a couple days ago per the factory manual procedure. Everything seemed fine until I thought I was done and the pedal had no pressure. Dammit! My Motive pressure bleeder let in a massive air bubble when I wasn't looking.
I tried bleeding every combination of ways. Pressure. Vacuum. Rear end up. Front end up.
This morning I pulled the master to bench bleed it. Reinstalled. The gallons of DOT 4 I have put through it look clear. Fluid going in looks clear. Still no pressure.
Any trick to getting some trapped air out of this setup?
Old 02-20-2017, 09:41 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Hmmm. It sounds like something is blocking the transfer of fluid/pressure from the bleeder.
Old 02-20-2017, 09:49 PM
sinKing's Avatar
The flow is fine. I'm getting gallons of fluid through the system, but there must be an air bubble trapped somewhere that the fluid is able to flow around.
Old 02-20-2017, 09:55 PM
brockster's Avatar
Ok is the power steering fill cap removed? Do you think you are full enough?
Old 02-20-2017, 09:58 PM
sinKing's Avatar
I have the GT2 conversion so reservoir up front going to the master, then master direct to slave.
Old 02-20-2017, 10:22 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
It is possible that your master is defective and failed. The seals maybe work at lower pressure on the bench but fail at higher pressure. Just a thought.
Old 02-20-2017, 10:27 PM
BLKMGK's Avatar
work the pedal while bleeding it. There's a cup seal in there and fluid must be both behind and in front of it to work properly. I'm currently writing up my fun swapping a master out for a billet one - the Motive was required for sure!
Old 02-21-2017, 07:42 AM
sinKing's Avatar
I guess anything is possible but I'm not leaning that way since it was working great before air got in and is only 10-12k miles old.
I tried that before the bench bleed but not after. If you found it effective I'll try it again. I have alternated between pedal down and up.
If nothing working in the next couple days (only working a few minutes after work) I may take out the master again and rebleed it. Maybe air got back in it when I reinstalled in between taking the caps out and connecting the lines.
I look forward to your write up.
Old 02-21-2017, 04:41 PM
BLKMGK's Avatar
Write up is posted but I need to finish some that was lost.
With a suction bleeder I got a stream of fluid and then nothing, I even sucked on the damn hose myself and while I could get a good vacuum I didn't draw any more than a drop of nasty fluid out. It held vac too! I cranked the Motive to 20 and as soon as the valve cracked a blast of air blew out followed by fluid. I cycled a bunch of fluid through it to be sure. I still had no pressure until the cap was put on and the bleed sealed (duh). While I had a steady stream coming out of it I moved the pedal full cycle and saw some change in movement in the Motive hose - you should too.
Hope it's easily fixed for you! If you really find that the OEM piece is toast shoot me a PM. I've got two sitting now, I'd bought one on eBay previously hoping to mod it lol and obviously the one I just pulled. If you've got an aftermarket clutch though and it's quirky talk to Sean!
Old 02-21-2017, 09:30 PM
sinKing's Avatar
After reading your thread I actually contacted Sean about that master to ask if it would help with pedal effort on my CM clutch.
I tried bleeding again tonight while working the pedal. Odd thing is it completely stopped flowing with pedal down but flowed fast pedal up. I pulled the master again, this time with the drivers seat removed and it was soooo much easier. I'll try bench bleeding again. If this doesn't work I'll try a new master.
Old 02-21-2017, 09:52 PM
brnrdtns's Avatar
Never read the manual for this but this is pretty simple to bleed. Have a friend hold the clutch down, crawl under the car and crack the screw open and close to let some pressurized fluid out, tell friend to go up and down again, crack screw, repeat. Every so many times top off the res. Get kind of fast at it to get all the bubbles. Are you doing something significantly different from that?
Old 02-21-2017, 09:57 PM
sinKing's Avatar
This is what I'm doing:
30 01 07 Bleeding the clutch system − GT2
 Note
 Filling/bleeding
Note
The clutch hydraulics must always be filled or bled using a pressure filling and bleeding device.
Furthermore, the bleeder valve must be opened sufficiently and the gauge pressure must be approx.
2.0 bar.
If there is no system pressure, before the system is filled or bled, the clutch pedal must be in the
"Pedal fully depressed" position. In order to avoid risk of injury or damage, the pedal must be guided
manually. Otherwise, the clutch pedal can move forward abruptly (as a result of servo kinematic
effects).
If the system was open previously (e.g. for component replacement), the minimum filling or bleeding
time must be 30 seconds.
Use only new Super DOT 4 brake fluid. This brake fluid is available under the following part
numbers: container volume 1 litre = 000.043.203.66, container volume 30 litres = 000.043.203.67.
top of page
Filling/bleeding
DANGER
Please note: danger of injury from depressing the clutch pedal, if there is no system pressure. The clutch pedal
will move forward abruptly as a result of servo kinematic effects.
· If the clutch pedal is fully depressed, the pedal must be guided manually.
1. If there is no or only lower system pressure, depress the clutch pedal fully. Guide the clutch pedal
manually.
2. Connect a bleeding device to the brake fluid reservoir. Switch on the bleeding device. Bleeding pressure is
approximately 2.0 bar.
3. The bleeder valve from the clutch slave cylinder (on the transmission) must be opened until clear,
bubble−free brake fluid emerges. Use a collecting bottle for precise examination of the emergingbrake fluid for cleanliness and freedom from bubbles.
4. Switch off and disconnect the bleeding device. Correct the brake fluid level if
necessary.
Old 02-21-2017, 10:06 PM
brnrdtns's Avatar
Try my redneck way, if it works there will be pressurized air and fluid coming out of the screw. I never used a bleeder device. It took a few bottles though.
Old 02-21-2017, 11:33 PM
BLKMGK's Avatar
Get a Motive, how I've lived without one is a mystery. Now I just need to find caps for other vehicles that don't cost an arm and a leg. Worth sacrificing an OEM cap to ,are an attachment if it comes to it.
Old 02-23-2017, 05:48 PM
sinKing's Avatar
Bench bled again, ran more fluid through, worked the pedal. Nothing. Starting to think the master is toast.
Ordered up one of SRM's trick master cylinders.
