Down she goes....
Old Aug 2, 2004 | 12:04 PM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
Cool Down she goes....
Well I decided to bring her down a bit, I have had a set of Gemballa Lowering Springs (made by H&R) in my garage for the last year. Gert helped me with the all the parts needed, I purchased Bilstein Sport Shocks, Euro rear bumpstops, also upgraded stabilizer bars. After looking at the factory stabilizer bar up front, I really didn't see much of a difference in the upgraded one, and it didn't look like a simple project to remove and install the new bar. So I passed on the stabilizer bars since Im really only looking for a lower look and slightly better handling on the track. Since the 996 only sees 1-2 track days per year I decided not to do the full PSS9's. The shocks were about $700 and I had the springs already $300. The stabilizer bars will go back to the dealer, so bumpstops were only $10. I started with the front since that was supposed to be the most difficult. I did one side on my own, but needed help on the other side, the difficult part is removing the strut while pushing down and avoiding the fender. This took two sets of hands. I have a air compressor so that came in very handy. Front was actually not that difficult, the rear was fun to say the least. You have to jack up the shock to line it up to fit the bolt at the bottom. Well that wasn't easy, of course once we figured out the secret the 2nd one was easier. All in all it was about a 5 hour project. I used the instructions from a guy over on the Rennlist board. They came in very handy. The ride is perfect height, not to low, I would say it lowered it about 3/4 of inch, and I think it will settle a little lower after more driving. As far as handling I noticed that it was slightly tighter around corners, and over bumps. Also I noticed that when I punch it, it didn't raise up the front end as much as it did before. I will get the full affect of the ride after Thunderhill on the 9th. OK here are some before & after pics...
Click pics for High Res Shots..
Before
After
Before (front)
After (front)
Before (rear)
After (rear)
After
After
Old Aug 2, 2004 | 12:15 PM
Kevin M's Avatar
Modaholic
1. Remove the shorud on the trunk with a torx screwdriver. t-20
2. Loosen the 18mm sway bar bolt that is in strut and remove
3. Loosen and remove the nuts that connect abs wires and brake line so you can move the arm more up and down. You might have to take out the caliper off the hub.
4. remove the 3 13mm bolts from the top of the trunk that holds the strut to the body.
5. Push down the arm and the strut will be in the wheel well.
6. this is the hard part push down the strut and pull it towards you to pull out of the wheel well. Becareful not to hit your fender. You might need to remove the 18 mm blot that conects the cross arm in the front to the main A arm so the arm has more movement. I did not need to.
7. once cleared you can slide out the strut from the spindle assembly and prepare the new one.
8. Remove the 21mm nut on top of the strut. Becareful I used a impact air wrench and push your weight down so the spring dosenot pop up in your face. The stock spring are not that strong so you can do this. Pay attention to how it comes appart. Put all the necessary parts on the new strut( bumpstop washer housing) and assemeble back wards. The new springs are shorter so the assemble may not have any tension.
9. If your car has Xenon lights remove the little sensor nuts that is hook up to the A arm. This is in the driver side
Old Aug 2, 2004 | 12:25 PM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
yeah!!!
Looks much betta!
Old Aug 2, 2004 | 12:28 PM
Kevin M's Avatar
Modaholic
All back together
Rear
1. Remove the long 18mm bolt connecting the strut to the arm
2. Disconnect both sides of the sway bar. 17mm open end and 15mm nut the bar should swing easy on the mounts.
3.Use pry bar, screwdriver to force the shock of its mount.
4. Go in the car remove the pannel behind the rear seat. It has no clips. Or for the cab, lower the top so the lid is open, then release the two wires to lift the back of the top up, one wire on each side, you can then access the area where the top of the strut is
5. Remove the 3 15mm nuts to drop the strut. Once the strut is droped you can prepare the new one. It is similar to preparing the front. Use the new bump stops. The nut on top is 18MM.
Kevin M's Avatar
Modaholic
6. install the strut back in the housing and don't tighten yet
7. place a jack under the shock to compress it so you can put it on the arm. It kind of hard. You need to be a little strong. Once on the arm the bolt wont align. Use a screw driver to lift up the shock just a little on the arm so you can push the bolt through. Once through assemble every thing back. In this pic I used spring compressors to tighten the springs down so we could get the bolt on
Old & New bumpstops
Thats about it..
Old Aug 2, 2004 | 01:22 PM
JakeMate's Avatar
JakeMate is infamous around these parts
Awesome write-up. Thanks.
Old Aug 2, 2004 | 02:10 PM
Itzkirb's Avatar
Damn Kev, that is looking sweet!
Old Aug 2, 2004 | 02:18 PM
ElusiveC4's Avatar
ElusiveC4 is infamous around these parts
very nice.. great step by step write up!
Old Aug 2, 2004 | 02:52 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Hey kevin, are those 18" or 19" Techarts? Looks damn good!
Old Aug 2, 2004 | 10:53 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
This is one for the record books. Very well planned out install and great shots. Car looks awesome.
Thanks!
Old Aug 2, 2004 | 10:56 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Don't forget about a 4-wheel alignment. You have changed the geometry of the suspension and will probably need it re-aligned.
Old Aug 2, 2004 | 11:27 PM
DJ's Avatar
DJ
Great Write up kev
Old Aug 3, 2004 | 01:09 AM
Kevin M's Avatar
Modaholic
Thanks guys .. Those are 19" Techarts..
Dave Im going to get it aligned after the Thunderhill Track Event.. I figure let it settle a bit.
Old Aug 3, 2004 | 01:31 AM
Redlinerobert's Avatar
Senior Member
Redlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond reputeRedlinerobert has a reputation beyond repute
Loos really good Kevin. I need help installing my brakes, sensor went off
Old Aug 3, 2004 | 01:39 AM
alrova's Avatar
alrova is infamous around these parts
cool, nice Job
