Advise On Lowering
Old Jan 18, 2008 | 12:16 PM
daytrader's Avatar
daytrader is infamous around these parts
Advise On Lowering
My friend has a 87 930 and he wants to lower the car. Any advises on where to start. Thanks!
Old Jan 18, 2008 | 08:36 PM
ZLP's Avatar
ZLP
ZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud of
Just re-index the torsion bars. It's pretty simple.
Old Jan 19, 2008 | 02:00 PM
daytrader's Avatar
Wow, I thought you have to upgrade shock/springs. Thanks!
Old Jan 19, 2008 | 05:26 PM
ZLP's Avatar
ZLP
LOL, pre '89 911's do not have coil springs....
Old Jan 19, 2008 | 08:05 PM
rgagliano's Avatar
rgagliano is infamous around these parts
As ZLP says, the don't have coil springs unless it has been converted to a coil over system. Take it to a reputable Porsche specialist and have it lowered to the european standards and then have it corner balanced and aligned. He will notice a great improvement on corners. Assuming this is a street use car you need to caution your friend that he then needs to try to avoid taking driveways head on as it will scrape. He will need to learn to angle his approaches into and out of driveways.
Old Jan 20, 2008 | 12:41 PM
Jitters's Avatar
Jitters is infamous around these parts
Hey Gents,
Thanks for the feedback. Not really familiar with what re-indexing the torsion bars mean; however, I've gleaned some information from another forum that explains how to adjust the ride height on the front. Unfortunately, I haven't been able to locate any information on lowering the rear...
I'm already familiar with angling the car as I enter and exit driveways due to the car being lowered and it having a front air damn...
Peter,
As always thanks for looking out for a brutha...
Jitters
Old Jan 20, 2008 | 08:57 PM
daytrader's Avatar
You're welcome, Todd! Anything to help a good friend and car lover like myself.
Old Jan 21, 2008 | 10:34 AM
_JD_'s Avatar
_JD_ is infamous around these parts
I'm ditching the torsion bars altogether and installing a set of Imagine Auto RSR coilovers. I'll post details and pics once the package arrives.
Old Jan 21, 2008 | 01:42 PM
Jitters's Avatar
Please do...Interested in seeing how it turns out...
Jitters
Old Jan 21, 2008 | 02:13 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
The RSR coilovers are really the way to go. Pull those old sagging torsion bars out of there, and update the suspension to something a bit more modern. One of my favorite upgrades on a 930. With a good suspension in the car, they are a lot of fun to drive.
Old Jan 21, 2008 | 10:47 PM
rgagliano's Avatar
JD and Doc, I am interested in how it works out too. I have been considering the same thing. You can have a 930/993. Doc, how extensive is the install?
Old Jan 21, 2008 | 10:49 PM
rgagliano's Avatar
Sorry guys, looks like I quadruple clutched the "post reply"
Old Jan 22, 2008 | 07:32 AM
I typically charge 8 hours for install, then you also of course need an alignment. If it is for a track car, then I recommend a corner balance as well, but for a street car there is no need to go quite that involved.
Definitely not rocket science as far as the install goes, removing the torsion bars is the hardest part as sometimes they are a little stuck after 30 years. Of course to get the ride height right, it takes a lot of put the car in the air, spin the collars up or down on the coil springs, put it down, get the suspension settled, check the height at all the corners, and repeat until you get everything even....so it is just mostly time consuming.
I should be having a car coming in later this week or next that I will be doing an install on, and I plan on doing a writeup with pictures to show the procedure.
Old Jan 22, 2008 | 09:34 AM
daytrader's Avatar
Guys, thanks for quick relies.
Old Jan 22, 2008 | 12:13 PM
rgagliano's Avatar
Doc:
Thanks so much for the post. I will be watching for the pics etc. By the way, I have talked to Stephen several times re. my 996TT and your stage 2 kits for that. I am also interested in one of your K27S turbos for the 89. Regards.
