ring and pinion
Old May 23, 2008 | 04:07 PM
cherry930's Avatar
cherry930 is infamous around these parts
ring and pinion
My mechanic just installed a ring and pinion in my tranny. I love how my car hits higher RPM faster especially after changing the cams, but it makes a "humming" noise in third and fourth gear (I have a 4 speed and before it wouldn't make that noise). My mechanic says its normal. Is this true? Your comments/advice are appreciated.
Old May 24, 2008 | 09:33 PM
ZLP's Avatar
ZLP
ZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud ofZLP has much to be proud of
Its normal.
Old May 24, 2008 | 09:42 PM
cherry930's Avatar
Thanks man. Love the flames.
Old Jul 15, 2008 | 11:55 AM
Erik @ Carquip's Avatar
Erik @ Carquip is infamous around these parts
The noise may disappear as the ring and pinion wear in a bit. Nothing to really worry about though.
Old Jul 19, 2008 | 08:57 PM
Arnie's Avatar
Arnie is infamous around these parts
Aligning the ring and pinion requires an expert. There should be no humming if it is aligned perfectly. It is not normal. Ask me how I know? Had a new ring pinion in my 71 911S was not aligned noticed the humming and it got progressively worse. An expert coates the teeth with yellow grease. When the grease is evenly distributed on the ring and pinion the alignment is correct. Keep an eye on it. If not you will ruin it.
Old Jul 26, 2008 | 03:56 PM
ZLP's Avatar
ZLP
You can do that and/or measure the backlash. Bother are pretty simple and imho don't require you to be an expert.
Steve Jarvis
Apr 1, 2023 06:49 PM
panas001
Sep 27, 2015 02:51 PM
