6 speed gearbox?
Old May 5, 2007 | 03:58 PM
Peppe's Avatar
Peppe is infamous around these parts
6 speed gearbox?
My brother owns a 964 Turbo. Its equipped with a 6 speed gearbox. One of the earlier owner had the 5speed gearbox replaced..
We have a discussion where the box come from
But..could it be a gearbox from a 993TT ?? Or is it a RUF Box?
Can we look for any marks/numbers somewhere on the box?
Old May 6, 2007 | 12:23 AM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Should have numbers on the undernearth of gearbox on a flat area about 70mm X 20 mm. Almost the lowest point of the box. Should read something like G50 20 or 21 or 32 ---or G64 etc -- then a serial number about 5/6 digits I think? . Post the number and that will help us identify it.
Old May 8, 2007 | 09:51 AM
riverflyer's Avatar
riverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud ofriverflyer has much to be proud of
I have a 993 6sp driveline in my 964. Don't get to use 6th much but its nice to have on the freeway.
Old May 10, 2007 | 07:23 PM
pete_vb's Avatar
pete_vb is infamous around these parts
Yea, the stock 6 speed box is pretty tall, especially if you've got a non- stock motor which revs higher...
We swapped ratios in the box in my '69- first is stock, 2nd and 3rd are custom, 4th is the stock 3rd moved to 4th, 5th is custom, and 6th is the stock 5th. Makes for about 175 mph at 7300 rpm in 6th, which is enough in a '69, but the rest of the middle gears are nice and short, and you're only buying 3 new gears. Highly recommended...
Old May 24, 2007 | 06:03 PM
WOODTSTER's Avatar
5 speed works better, no need to put a six in.
In a six, first is so short and sixth is so tall.
MK
Old May 25, 2007 | 03:21 PM
pete_vb's Avatar
It is true that the wide torque band of the 965 doesn't benefit as much from the 6 speed, and it's also true that US 6 speeds have widely spaced ratios. To say the 5 speed "works better" is oversimplifying to the point of error, though.
The 993 6 speed has on the order of half the shift effort of the 5 speed, ie the synchros spin up quicker for faster shifting. There is a small weight penalty which is outweighed by the better ratio spacing, especially for track use. Geared correctly (not cheap) it’s a great gearbox. A link to a discussion of some of the gearing options:
http://forums.pelicanparts.com/showt...hreadid=276073
Old Jul 16, 2007 | 10:27 PM
Ag02M5's Avatar
Ag02M5 has a spectacular aura aboutAg02M5 has a spectacular aura about
I'd love a 993 ROW box. The stock 5 sp is way too tall!
Old Jul 18, 2007 | 10:07 PM
LARennsport's Avatar
LARennsport is infamous around these parts
I've got a 993 6-speed in my 964 as well...no brainer...bolts in.
Old Jul 20, 2007 | 07:57 AM
Ag02M5's Avatar
US or ROW?
Texas1
Sep 20, 2015 09:12 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
Suds26
Sep 2, 2015 01:33 PM
